1999 EM1 B16a2 LAG Problem. (HELP)
Old Feb 23, 2012 | 07:50 PM
BaSikMuSic's Avatar
Icon2 1999 EM1 B16a2 LAG Problem. (HELP)
Hi i have a 99 civic si b16a2. I Recently got a lag going. When i take off, it startes with the lag. the rpm starts going crazy and starts just going in and out of power(Laggy). idk if its because of the fuel line or gas is dirty. i took it for a ride while it was cold. and nothing. once it started warming up its started with the lag. rpm is fine when its warm and sitting but when u rev it it starts with the lag again. PLEASE HELP!!!!
I tried a Water Removal Gas Treatment. but nothing.
Old Feb 24, 2012 | 05:03 AM
kyden's Avatar
Default Re: 1999 EM1 B16a2 LAG Problem. (HELP)
when was the last tuneup?
Old Feb 24, 2012 | 07:09 AM
c5stunna's Avatar
do u have a check engine light? sounds like your throttle position sensor. you wont always get a check engine light from it either
Old Feb 24, 2012 | 09:09 AM
98civdx's Avatar
Master Detailer
Last tune up? Have you checked the ignition timing? Cel's? Any major work done to the car?
Also, at your next fill up run some good fuel system cleaner threw it.
Old Feb 24, 2012 | 09:14 AM
Dc4LsTeG's Avatar
EK9
As said any cels? Id check your dizzy
Old Feb 24, 2012 | 10:10 AM
Jdmbryan's Avatar
op died?
Old Feb 24, 2012 | 10:15 PM
BaSikMuSic's Avatar
when i turn the car on no lights are on and when its starts to lag thats when it turn on. & the car has been parked in a garage for 6 months till now that i got the money for insurance.
Old Feb 24, 2012 | 10:22 PM
BaSikMuSic's Avatar
wats cels?
i have but didnt mess with it.
& no major but its swap & new clutch. but it all started after that.
i was planning on putting a fuel inj cleaner and Plus gas & try that.
Old Feb 24, 2012 | 10:39 PM
98civdx's Avatar
Master Detailer
Originally Posted by BaSikMuSic
wats cels?
Check engine lights
Old Feb 25, 2012 | 07:15 AM
98greensi's Avatar
mine does the same thing. my problem is a sticky idle air control valve. runs fine and when it starts to run like **** the cel comes on. try this when it starts to act up shut the engine off and then restart it, this stops my issues for awhile. there are some write ups on here on how to clean the iacv (idle air control valve) I've just been busy and haven't got around to doing mine
Old Feb 25, 2012 | 08:09 AM
BaSikMuSic's Avatar
i will try cleaning the iacv and keep u guys updated
THANKSZ
Old Feb 25, 2012 | 08:34 AM
Dc4LsTeG's Avatar
EK9
So any cels?
Old Feb 25, 2012 | 08:55 AM
BaSikMuSic's Avatar
when it starts to lag and starts to jerk it turns on.
sunday im going to check for the code and ill give u it.
i would have turn the car off so it can turn off.
Old Feb 27, 2012 | 05:44 PM
BaSikMuSic's Avatar
so i think i found the prblm. i put the wrong gas -______- i never knew em1 are only premuim
Old Feb 27, 2012 | 06:15 PM
civicjunkie17's Avatar
Look in your owners manual. B series Vtec are designed to run 91 octane. Something with a lesser octane will cause pre ignition.
Remember the octane of gas does not mean it's a better quality gas but that it is more resistant to combustion.
Old Feb 27, 2012 | 06:51 PM
AyoSmokie's Avatar
Originally Posted by Jdmbryan
op died?
Old Feb 27, 2012 | 08:38 PM
BaSikMuSic's Avatar
i did read it. 93 premium. I was dumb at first and put regular and that when it started the lag.
allmotorgsr98
Dec 10, 2013 02:19 PM
98bucket
Jul 10, 2010 12:15 PM
DC2_fan1999
May 5, 2007 10:03 PM
xbn83
Jan 10, 2005 08:07 AM
CRiX
Dec 30, 2001 07:15 PM
