Air Breathers????
Do air breathers on the crankcase actually contribute to better performance and cleanliness or are they just a marketing gimmick? They are fairly inexpensive and I was wondering if anyone has any experience using them? Thank you for your time!
You won't pass a visual emissions inspection and you'll smell the unburned fumes that escape your cylinder head.
If you're ok with this, then go for it.
If you want a legal solution to not sucking in oil and crud from the top of your motor, use a catch can without a breather filter.
Well, youll gain some performance if vented correctly as the crankcase doesnt have pressure build up.
just like the honda engines are restrictive, same goes for the pcv system.. its all for emissions.
Catch can is not needed on a stock engine. Don't know what mudslide you drove through but i have NEVER had ANY of my intakes for ANY of my Hondas look like that.
