Air Breathers????
Old 02-23-2012, 07:45 AM
04simpson's Avatar
Icon2 Air Breathers????
Do air breathers on the crankcase actually contribute to better performance and cleanliness or are they just a marketing gimmick? They are fairly inexpensive and I was wondering if anyone has any experience using them? Thank you for your time!
Old 02-23-2012, 07:48 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Air Breathers????
No performance difference. I'd just rather not have any of whatever's coming out of the valve cover routed back into the intake air.
Old 02-23-2012, 08:35 AM
04simpson's Avatar
Is it going to release that much gas?
Old 02-23-2012, 08:44 AM
The Grumpiest
What?
Old 02-23-2012, 09:17 AM
04simpson's Avatar
that the intake (in my case an aem v2) will be sucking it back through?
Old 02-23-2012, 09:19 AM
The Grumpiest
Why don't you take off the hose and see?
Old 02-23-2012, 10:47 AM
04simpson's Avatar
I was just wondering man... I am going to but if someone had previous experience then it would save some time.
Old 02-23-2012, 10:52 AM
Red_Army's Avatar
they're a breather. pretty basic.
what gases do you think are being made way up in the head?
google it. ya know on your own.
Old 02-23-2012, 10:57 AM
Texas4door's Avatar
You won't pass a visual emissions inspection and you'll smell the unburned fumes that escape your cylinder head.
If you're ok with this, then go for it.
If you want a legal solution to not sucking in oil and crud from the top of your motor, use a catch can without a breather filter.
Old 02-23-2012, 02:51 PM
Retired Moderator
EsotericImage's Avatar
Well, youll gain some performance if vented correctly as the crankcase doesnt have pressure build up.
just like the honda engines are restrictive, same goes for the pcv system.. its all for emissions.
Old 02-23-2012, 03:12 PM
The Grumpiest
Doesn't really do anything on a stock engine.
Old 02-23-2012, 03:17 PM
Retired Moderator
Old 02-23-2012, 03:58 PM
SKAVENGER88's Avatar
A breather isn't needed and u get no performance gain. Just put on a catch can or you might end up with this.
Old 02-23-2012, 04:02 PM
The Grumpiest
Catch can is not needed on a stock engine. Don't know what mudslide you drove through but i have NEVER had ANY of my intakes for ANY of my Hondas look like that.
Old 02-23-2012, 04:09 PM
That's oil. Turbo d15 no catch can. Lesson learned
Old 02-23-2012, 04:11 PM
The Grumpiest
Again. Not. Needed. On. A. Stock. Engine.
And my intake doesn't look like that and I'm boosted.
Old 02-23-2012, 04:25 PM
Retired Moderator
mine either!
Old 02-23-2012, 04:29 PM
True not needed but never hurts to run one.
Old 02-23-2012, 05:53 PM
Texas4door's Avatar
Hell, I run one because the baffle in my valve cover is missing and I don't wanna ingest oil through the hose
XD;
Old 02-24-2012, 03:26 AM
ddd4114's Avatar
(image)
Either your PCV valve is clogged, or you have seriously blow-by issues. Was this autocrossed or tracked?
tweek_boii
12-15-2007 09:44 AM
IntegraTypeR777
07-15-2007 01:42 PM
accordmaniac23
03-07-2007 07:44 AM
rive22
08-02-2004 05:51 PM
JimmyAtlantis
13
12-26-2003 12:24 PM
Quick Reply: Air Breathers????
