6 speed question
Old Feb 19, 2012 | 11:09 PM
decon's Avatar
Default 6 speed question
Hey guys i tryed to search this but when i seach it takes out the 6 so didnt help me at all. But other then a k swap with the 6 speed. Is there any other tranmissions out there that will work with an em1 that is a 6 speed?
Old Feb 19, 2012 | 11:18 PM
mondojackal's Avatar
Default Re: 6 speed question
Nope. Only Honda offered 6-speeds are K-series (RSX-S or TSX), C-series (NSX), J-series (Accord V6 or TL V6) and F-series (S2000).
Old Feb 20, 2012 | 12:11 AM
Texas4door's Avatar
Nothing OEM anyways....doesn't mean you can't shell out and have one made but is it really worth it?
How fast are you planning on going with that extra gear anyways?
Old Feb 20, 2012 | 02:30 AM
Libertariat's Avatar
Ek Forever y0!
Why do you want to shift more?
There's nothing really advantageous about having 6 gears...
If I told you you could have 14 gears, would that be more exciting? Why is 6 more exciting than 5?
Old Feb 20, 2012 | 02:38 AM
jbpnoman's Avatar
Why has no one made a joke about Civics and powerband shifting? H-T, I am disappoint.
Old Feb 20, 2012 | 04:00 AM
decon's Avatar
Mostly want it for the gas mileage when driving on the freeways and such. Only real reason behind it. But if only option is an k swap that's way out of the question just for gas mileage. Granted a em1 with a k20 and 6 speed would be awesome to have as a daily driver, well to me anyways.
Thanks all for the input.
Old Feb 20, 2012 | 04:45 AM
Ek Forever y0!
A tall 5th or a tall 6th doesn't really matter. There are plenty of folks with h22/h23's with 5 speed transmissions getting 35mpg.
A 6th gear doesn't necessarily mean better mileage, but it definitely means more shifting.
Old Feb 20, 2012 | 06:01 AM
Red_Army's Avatar
get longer gears. you can change the gearing for more MPG before getting a 6 speed would be worth it.
Old Feb 20, 2012 | 06:29 AM
decon's Avatar
thanks guys... I have to relearn the honda world, i left in 06 when i sold off my ep3 for a wrx.
Old Feb 20, 2012 | 10:07 AM
canadaek's Avatar
put an ls 5th gear into your si trans
Old Feb 20, 2012 | 12:51 PM
94EG8's Avatar
Seagull Management
Exactly, just to clear something up 6th gear in a K-series ends being about the same as 5th on a GS-R tranny, maybe even closer to a B16/ITR in terms of cruising RPM.
Old Feb 20, 2012 | 01:31 PM
98civdx's Avatar
Master Detailer
Aren't the type S transmissions still geared pretty short?
Old Feb 20, 2012 | 01:42 PM
Deetz's Avatar
Crazy Honda Guy
I can tell you the non S 5 speed tranny has the same FD, as well as the 1st gear being the same, and the 5 gear in one and sixth gear in the other are also the same.
The type S just has more gears in between
99CoupeEK
Feb 21, 2019 10:45 AM
oem_CD5
Jan 3, 2007 01:25 PM
Matthias
Oct 10, 2005 08:04 PM
smslude
Nov 22, 2002 11:53 AM
Veil_Side_
Jan 30, 2002 08:24 AM
