Some help with some definitions please
Old Jan 30, 2002 | 08:15 AM
Veil_Side_'s Avatar
Default Some help with some definitions please
This will eventually lead to a different topic but I need to get some things straight,
what does it mean when people speak about "Close ratio gears"?
Torque converters with "3500 rpm stall(or whatever the number)?"
Old Jan 30, 2002 | 08:19 AM
Spade's Avatar
Default Re: Some help with some definitions please (Veil_Side_)
I can answer the gears.
Close means when you shift it only drops about 1200 RPM instead of well, 1500....follow me?
Old Jan 30, 2002 | 08:24 AM
allenp's Avatar
Close ratio gears: In a transmission, each gear has a distinct ratio by which it multiplies speed: for example 4:1, 2.5:1, etc. If the ratios are "close," there is not a dramatic step in between the numerical ratios. Practically speaking, when you're driving and shifting, the shifts will be quicker because it takes less time to drop/rise to the next gear's RPM.
To find the stall speed of a torque converter: Put the transmission in D, hold your foot on the brake, and floor the throttle. The engine speed reached is the stall speed.
99CoupeEK
Feb 21, 2019 10:45 AM
hondacrx2
14
Jul 27, 2011 04:40 PM
pkprelude
May 8, 2003 07:58 PM
pkprelude
May 8, 2003 04:48 PM
