Idle problems on d16y8
I have a d16y8 and when i go start the car about 5 mins later my idle goes up and down like crazy and wont stop till like 5 or 8 minutes later this being happening for the past few weeks.... Note that i had had that problem b4 and some one told me it was my iacv i was told to clean it or buy a new 1 but i didnt had a good income long story short i clean it with brake cleaner like i was told and problem was fix since sumer time now is back.... Question is the problem back or could it be something else help!!!!!!
did you do this?
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
do some searching. crap ton of information on idle issues.
here's some threads for ya. it's not hard to search. these took me 10 seconds to find.
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/problems-idle-iacv-code-14-p0505-look-here-2127246/ <-- found that one in FAQ
http://i639.photobucket.com/albums/u...cture_4661.jpg
Check for vacuum leaks, with the engine running spray brake cleaner around hoses near the throttle body, intake area, don't over due it, if you hear a change in sound as it runs chances are that is your problem, of it it dies.
Bwill9886
Jul 27, 2009 08:43 AM
