500+whp ls-vtec sc61 e85 powered by cast iron log manifold possible?
I was wondering if it is possible to make 500whp or more on a cast iron log manifold because I have went with ramhorn type manifolds and they keep on cracking.
My setup consists of:
96 B18c1 head and 95 b18c1 block filled with block filler
ls crank micropolished all new bearings and thrust bearings also
srp 8:5:1 compression pistons with eagle rods
arp head studs
golden eagle oil squirter plugs
all new gaskets and belts
stage 5 4 puck unsprung clutch masters clutch
stock flywheel, axels, gsr transmission open differential
Precision sc61 turbo rebuilt k&n air filter
cast iron log turbo manifold inline pro ss copy basically tuned with mini ram horn before though
3 inch open downpipe
tial 38mm wastegate
greddy type s knock off bov, 2.5 inch intercooler piping, intercooler 32 by 12 by 3
ngk wires ngk bkr7es
stock intake manifold thinking about getting blox or edelbrock victor x
speedfactory 4 bar
aem fuel rail
1200cc injectors precision
255 walbro fuel pump with upgraded harness
p28 chipped ecu on crome e85 342whp on 15 psi turbo seized up thinking about hondata s300
ebay catch can with vented valve cover
hallman ez boost controller manual
fast turbo oil line kit
aem uego, prosport oil pressure gauge, boost, fuel pressure
polyurethane filled motor mounts with torque mount bar
10w 40 oil with glowshift oil sandwich adapter plate
block off plug for black box
Wondering if I can make 500whp or more on this setup this upcoming season on e85?
arp head studs
tial 38mm wastegate
speedfactory 4 bar
aem fuel rail
I'm running an inline pro log with an Sc61 lsvtec also hoping to break 500whp..our setups are pretty similar I have alittle more compression 9.5:1...what do you have for cams? You should upgrade to maybe some itr's or stage 1 motor cams to help..I'm spraying my 35shot if I don't reach my goal
alperx
Jun 25, 2012 11:11 PM
joepiscapo_83
Dec 1, 2004 08:17 AM
, thanks really appreciate it guys!!!!!!!1
