Boostie 2012
New project for the year is coming together and have a few final pieces to decide on to finalize the build. I have no goals other than to have a well matched fun car. I have everything narrowed down except the cams and intake manifold, I haven't seen anyone make a decent attempt at making the BC3+ cams work. The 5858 is a 60+lb/min turbo and is on the edge of being able to take advantage of a "larger" cam. The BC3+ is a smaller version of the Pro1 which is one of the current big turbo cams of choice.
Stock Sleeve GSR
Mahle pistons ~10.5:1
Manley Rods
GSR head CC Ported
+1mm Intake Valves
Supertech Springs, Guides and Retainers
BDL cam Geaars
(Cams?) GSR/ITR/BC3+ (have all 3)
(Intake Manifold) Have Blox...... buy Victor?
Synapse Ramhorn
46mm Precision Wastegate
3" DP
Precision 5858SP-BB
Full Race 22x8x3 Backdoor IC
2.5" charge piping
Tial 50mm BOV
93 Octane
ID 725cc Injectors
DW301 Pump
AEM Methanol Injection
Fuel Lab FPR
Stock Sleeve GSR
Manley Rods
GSR head CC Ported
+1mm Intake Valves
BDL cam Geaars
Synapse Ramhorn
3" DP
Precision 5858SP-BB
2.5" charge piping
Tial 50mm BOV
93 Octane
ID 725cc Injectors
DW301 Pump
Fuel Lab FPR
Ive gone
D15--->DOHC ZC--->B20--->Cookie--->B20 Revisited--->B20 Supercharged--->GSR Supercharged--->Boostie
Are those Natural Aspirations?
Great set up.. i would go with the victor and itr cams but that depends on Ur power goals... With Ur compression its gonna make great power and I see Ur gonna use meth..
Good setup, Choose the profile that best utilizes what you are trying to do. Being a turbo car, i suggest running a hybrid cam setup.. medium sized intake with a good sized exhaust.
ID1000's ordered just to be safe along with a 4Bar. Will likely be running the S2s1's after talking with Derrek (D-Rob) it seems like the logical choice for my goals. Morgan said the manifold will be shipping this week. Oil lines came from Go-Auto last week, I think all I have left to purchase is an exhaust.
Any advise on exhausts? VRS seems to be the best priced piping kit, but by the time I have all the parts for the system bought and welded together I could have bought a complete cat-back such as the skunk2 76mm megapower RR. The $120 eBay 3" is a bit tempting as well, I have a buddie who has one and has not had any issues.
Almost...... I ended up with the incorrect DP so it will be another week until its running.
Talking with Rocket about a set of M21's will likely be going with a set of those which is a CTR+ profile for the most part.
Camshaft choices always haunt me because there are always more choices than information out there. One of the few cams that have been done back to back are the ITR and Pro1, which happen to be the 2 most popular choices. On the famous test ~60whp was picked up by switching to a Pro1 cam with a 35 lb/min turbo, while my turbo is a little bit smaller than that there has to be a compromise between the two choices with all of the options out there.
While I'm not looking to break any records I am looking to produce the most efficient combination I can.
Not true, I'm always open for suggestions.
Camshaft choices always haunt me because there are always more choices than information out there. One of the few cams that have been done back to back are the ITR and Pro1, which happen to be the 2 most popular choices. On the famous test ~60whp was picked up by switching to a Pro1 cam with a 35R turbo, while my turbo is a little bit smaller than that there has to be a compromise between the two choices with all of the options out there.
cut the piping to make it fit without bumper modification. looks like if u cut 4 inches off the end going to the intercooler it will be about where u want it, hard to tell from that angle.
I cut ~3" off the end that comes out of the IC to get the proper got with the turbo connected to the inlet. The length after the first bend I a bit too long an rather than have 2 bends it has 1 90 degree bend and it just sticks out too far.
u have no other bends left over that work. the kit i got also fit like **** i ended up having to use my old n/a cold air pipe to make it work cuz i used up all the bends, thats why i have it going from 2.5 to 3 inch. i u look at the motor shot in my garage you'll see what i mean. would full race take the kit back if u already cut it?
Well after a bunch of cutting I got things to fit, interesting how custom parts require "adjustment"
Still looking into cams...... I will likely leave the GSR cams in the engine until I can make a decision. Im waiting for some more information about the GSC cams, but it's nowhere to be found just yet.
