2000 Civic dx CEL code p0141
Old Feb 14, 2012 | 11:10 AM
dlstech's Avatar
Default 2000 Civic dx CEL code p0141
I just tried to pass emissions but the Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor2) code came up. Do I just change the sensor and reset the computer or is there more to it than that?
Old Feb 14, 2012 | 01:54 PM
dlstech's Avatar
Default Re: 2000 Civic dx CEL code p0141
Also, I remembered reading somewhere about this code and fuse #4 being blown. Well I looked and I'm completely missing fuse 4. What is that fuse for?
Old Feb 14, 2012 | 01:59 PM
HondaPartsHero's Avatar
Technical Hero
Measure the resistance between 3 and 4 on the O2 sensor, should be between 10-40, if not replace the sensor
Old Feb 15, 2012 | 11:18 AM
dlstech's Avatar
Is this the lower sensor here?(green wire)? Or is it one under the car? I'm new to hondas and not sure if these engines have 2 or 4 sensors.
If so, it shows an open. also the wire looks really frayed. Checked the top one and the resistance was 11 ohms.
Old Feb 15, 2012 | 11:29 AM
Technical Hero
Yeah green one, that could be your issue. Looks like you're missing your splash shield. You might want to pick one up to prevent this from happening. Also prevent water from splashing up on sensor and such.
Keevin77
Oct 28, 2011 06:18 PM
dhdave2509
Apr 11, 2010 09:02 AM
soundFX
Mar 17, 2007 09:39 AM
Cashbrun
Oct 1, 2005 09:47 PM
shalemain
Sep 23, 2004 08:07 AM
