98 Civic EX Running Hot!
Old Feb 14, 2012 | 09:28 AM
ksjohnsonEK09's Avatar
Default 98 Civic EX Running Hot!
Hey I'm hoping to get some help with my overheating issue. Just this morning my car started running hot. If I kick the heat on full blast it seems to settle back to normal-ish but still running slightly high. Any ideas??
Old Feb 14, 2012 | 09:40 AM
Dc4LsTeG's Avatar
EK9
Default Re: 98 Civic EX Running Hot!
Fan coming on? Could be fan,themostat, or head gasket. We need more info
Old Feb 14, 2012 | 11:07 AM
Blacknight117's Avatar
Car? Engine? CEL? Info man. Check the obvious though, do you have enough coolant? And like Dc4 said, fan coming on??
Old Feb 14, 2012 | 11:11 AM
I just noticed it on my way to work. Pretty sure the fan is coming on and it has coolant. I had to disconnet the hose that runs from the thermostat to the head the other day to access the harness behind it. Could there just be air in the system?
Old Feb 14, 2012 | 11:13 AM
Why would turning the heater on make it retun to normal temp?
Old Feb 14, 2012 | 11:26 AM
motegicivic's Avatar
Helps to circulate coolant.
You need to see when it runs hot, driving or idling or both?
Old Feb 14, 2012 | 11:59 AM
It`s possible..bleed the system and get all the air out and see if it still overheats..
Old Feb 14, 2012 | 03:58 PM
Ok just got a chance to look at it a bit. The fan is kicking on. It's only getting hot while running, not just idling. The upper radiator hose swells slightly and very hot. The lower hose appears normal and has pressure. Once it cools down I'm going to check the coolant level. There isn't anything in the overflow reservoir. Any thoughts?
Old Feb 14, 2012 | 04:14 PM
grumblemarc's Avatar
The Grumpiest
Hot while driving? I suspect bad radiator.
Did you bleed the air from the system?
Old Feb 14, 2012 | 04:41 PM
96dxcrapbox's Avatar
air in your system......... especially if you just pulled a hose loose.
the res being empty too?? your cooling system was compensating for the coolant loss
top off the radiator and the res.
Old Feb 14, 2012 | 05:25 PM
Alright hopefully that's the only issue. I'll try bleeding the system and see where that gets me.
Old Feb 14, 2012 | 08:52 PM
Cjlarson14's Avatar
I agree with grumble. Suspect a bad radiator. Air in the system in my experience has never really caused overheating issues, just idling issues. If you car idles fine then air wouldn't be the problem. Also your radiator cap could not be sealing properly or the gasket could be bad and not maintaing proper pressure through the system.
98civd16y8
May 22, 2013 01:32 AM
GringoZX
Sep 9, 2012 03:06 PM
heyitsaej8
Nov 15, 2010 12:37 PM
Psych0Thrasher
Aug 26, 2009 04:05 PM
the.hamburglar
Jun 15, 2008 11:27 AM
