99-00 SI gauge cluster into 00 Ex - How retain Ex odometer and Si speedo face plate?
Old Feb 12, 2012 | 05:49 PM
bpl0807's Avatar
Default 99-00 SI gauge cluster into 00 Ex - How retain Ex odometer and Si speedo face plate?
Im about to buy a 2000 si gauge cluster to put in my 2000 ex automatic (manual swap coming eventually lol). When I realized... The mileage shown will be different than the actual on my car. Is it possible when I swap the clusters to one: swap the EX SPEEDOMETER into the SI cluster and just put the SI face on it, or if that doesn't work is it possible to set the SI one back or forward to the mileage shown on the EX speedo and then put it in, or will that break it? Any help would be appreciated.
Old Feb 12, 2012 | 05:53 PM
phoxking's Avatar
Default Re: Quick question about 99-00 SI and Ex gauge cluster
yes it is possible, open up the cluster! just be careful not to mess anything inside, i forgot the details but you should be able to figure it out from there.
Old Feb 12, 2012 | 05:54 PM
deving916's Avatar
you can roll a cluster back/forward but I believe it's "illegal" and it does show up on a carfax if you change the mileage
I'm not sure about the changing the faces but if you take the cluster apart you have to like move the tiny little gears carefully or they'll break
Old Feb 12, 2012 | 07:44 PM
SpeedoKing's Avatar
It is possible to change the mileage on any ek cluster, I have done it many times. I too purchased a SI for my EX and had to roll the mileage on the SI forward to match the one I was taking out of my EX. Whether it is illegal or not I am not sure, as long are you are not changing the mileage to make a profit on the car you should be fine. You should also know before you put the SI cluster into your car that the speedo will be fast by about 7mph because the speedo sensor on the B series trans is different then the one on your D. Whether you can swap the sensors out, I am not sure. But here are the steps to changing the mileage, sorry I have no pics but I will do my best to be percise.
1. remove the clear plastic cover on the speedo, there should be 5 or 6 tabs holding it on. it should just pop off.
2. next remove the black plastic cover surrounding the speedo, tach, temp, and gas gauges. This too should be held on by a few clips and will pop right off.
3. This is where you have to be very careful. You will need to remove the speedo needle, take two small flat head screwdrivers and place them between the speedo needle and the faceplate. Then gently pry the needle off, this can be hard because sometimes the needle is on there kinda hard.
4. once you get the needle off there are two screws holding the face plate onto the cluster. Remove the screws then lift off the faceplate.
5. Now it is time the change the mileage, you will see the tumblers with the mileage numbers on them and on the top and bottom of the tumblers you will see white plastic gears that can be pried off so that the mileage tumblers can be moved freely. Be careful NOT TO COMPLETELY REMOVE the white gears that hold the mileage tumblers in place. I found that I could only change the thousands and not the hundreds on the miles (for example 123,456. I can change the 123 and not the 456).
6. once you have the mileage set to where you need it put the faceplate back on and hook the cluster back up to your car, and start your car then place the needle back on the speedo. This will make sure that the needle is on zero mph. you can then unhook the speedo and replace the rest of the parts.
that is the best explanation i can give to you. You may be able to find a write up with pics somewhere. I DO NOT TAKE RESPONSIBILITY FOR ANY DAMAGE YOU DO TO YOUR CLUSTER. best of luck man.
Old Feb 13, 2012 | 05:11 PM
bpl0807's Avatar
Do you know about swapping just the faces?
Old Feb 13, 2012 | 06:58 PM
SpeedoKing's Avatar
im sure it is possible I have seen people do it with the temp and fuel gauges but not with the speedo. I think that the tach and speedo assembly are separate too so it wouldn't matter, but you would have to take a look because I am not sure.
Old Feb 14, 2012 | 07:21 AM
96dxcrapbox's Avatar
its a cake walk.
you can keep your mileage by swapping out the speedo portion of the cluster like you stated. before you open the the cluster up on the back side of it in the middle there is 4 screws remove them then remove the plastic tabs the clear portion and the black portion should pop out together. there is two upper light bulbs on the front of the cluster.\pull those too. lift out the face if you want too swap them now is your chance. the speedo just lifts out put your old speedo in the new cluster and you are good to go
i did this yesterday so i could gain a tach ......it took 15 minutes.
let me know if you need pics
Old Feb 14, 2012 | 07:47 AM
Civic2Fast's Avatar
Originally Posted by 96dxcrapbox
its a cake walk.
Spot on... just swap odometers
Old Feb 14, 2012 | 08:04 AM
94EG8's Avatar
Seagull Management
You can't do it on an Si cluster. Well you can, but it looks ridiculous since the Si speedometer head looks completely different than all other '96 - '00 Speedometer heads. I don't think you can swap the faces either, IIRC the spacing between the numbers is different.
Old Feb 14, 2012 | 04:29 PM
the swap i did was from dx to ex..........oops
Old May 18, 2012 | 04:45 AM
Danny Sihapanya's Avatar
its a cake walk.
So I can do that without taking out the needles? Sorry for bump. :S
Old May 18, 2012 | 05:57 AM
Former User's Avatar
Default Re: 99-00 SI gauge cluster into 00 Ex - How retain Ex odometer and Si speedo face pla
Old thread closed.
Uxi
Feb 23, 2008 08:35 AM
LSVTEC408
Northern California (Sales)
May 27, 2007 06:01 PM
cappa
Dec 13, 2004 06:23 PM
simplegreenmachine
Oct 6, 2002 10:28 AM
b16b hatch
Jan 9, 2002 08:21 PM
