LSV Running filty rich help
I have a lsv in a 90 crx si. b16 pistons stock bottom end stock fresh b16 head type r intake and throttle body. The car is running super rich it shoots raw gas out the exhaust and im also getting about 130 to a tank. I have changed the injectors check the fuel pressure and its at around 35 psi. I replaced the MAP TPS FPS coolant temp sensor and none of this helped. I was running OBD0 injectors then put OBD1 in and wired them up and did not help. Anyone have any ideas?
pro1342
13
Sep 13, 2005 12:01 PM
93c1sol
Sep 8, 2005 11:06 AM
