b16 idles rough
Old May 13, 2011 | 07:23 PM
NoLeftTurn's Avatar
Default b16 idles rough
I am having problem with my car running rough. Its a stock b16 with gsr cams. I have a walboro 255 with id1000's. Running a b16 turbo basemap sent from a tuner. My vac gauge reads -9 psi, my wideband reads lean 21.8, but im running an open downpipe until I get my exhaust back. I have check the compression 200,190,200,200. At first I thought it was my injectors because when I d/c 1 and 4, the engine would die but when i d/c 2,3 no change. Pulled spark plugs and there is gas on top of it. Any suggestions would help a bunch.
Old May 13, 2011 | 07:55 PM
ashb82's Avatar
Default Re: b16 idles rough
what map sensor you got. sounds like the car needs a good tune
Old May 13, 2011 | 09:17 PM
NoLeftTurn's Avatar
its a gm 3 bar. I got a basemap from a tuner for now. Ill get a tune once I get this fixed. I dont know what else could affect my vac reading.
Old May 14, 2011 | 10:10 AM
ashb82's Avatar
where are you getting you vac source from going to the map sensor
Old May 14, 2011 | 10:19 AM
h22-eg-hatch's Avatar
Get a good tune. Should fix everything.
I'm reading -20 on my vac gauge at idle.
U might have a big vacuum leak that was fixed by adding fuel to make it idle.
If ur reading -9. There's prob the issue
Old May 14, 2011 | 03:20 PM
NoLeftTurn's Avatar
vacuum block with no t's
Old May 14, 2011 | 03:22 PM
NoLeftTurn's Avatar
Im reading vacuum off of my boost gauge. Maybe I should get check if off the vacuum block.
Old May 14, 2011 | 03:51 PM
ashb82's Avatar
what is the rpm at idle
Old May 14, 2011 | 05:09 PM
NoLeftTurn's Avatar
roughly around 1000
Old May 14, 2011 | 05:25 PM
Vtec6000's Avatar
If it's running at 21.8 air/fuel ratio at idle no wonder the idle is crap, add some fuel to bring it down to 14.7-15.0 air/fuel ratio
Old May 14, 2011 | 09:45 PM
NoLeftTurn's Avatar
I think it might be the tune. Ill post datalog off hondata tomorrow.
Old May 15, 2011 | 06:31 AM
Vtec6000's Avatar
If you post up map +datalog I can take a look to see what's going on. Drop me a pm either.
Old May 17, 2011 | 06:04 PM
NoLeftTurn's Avatar
Pmed.
Cian Mcloughlin
May 20, 2013 10:11 AM
pro1342
13
Sep 13, 2005 12:01 PM
blackmagicCRX
Mar 12, 2005 10:00 PM
kaj
Aug 1, 2004 10:25 AM
sirminder
Jun 18, 2002 04:52 AM
