High idle when IACV plugged in
I am having a idle problem in my 97 civic with gsr swap. I'm sure its a problem with the iacv cause with it plugged in it idles at almost 2000 rpm. Then I cover the port on the tb and it idles perfect like normal then if i unplug it the idle goes down and jumps. So is this a bad iacv?
if you cover the whole t/b does the car die ? check throttle cable adjustment ,idle air bleed screw, and throttle stop(do not adjust this) if there all ok replace iacv
No CEL what so ever and I said that I tried to clean it already. Replaced the ECT sensor with another one I had laying around and same result. Haven't repaced the TPS yet, but I do have another TPS.
carlos8
Jul 16, 2011 11:32 AM
