High idle when IACV plugged in
I am having a idle problem in my 97 civic with gsr swap. I'm sure its a problem with the iacv cause with it plugged in it idles at almost 2000 rpm. Then I cover the port on the tb and it idles perfect like normal then if i unplug it the idle goes down and jumps. So is this a bad iacv?
Re: IACV Problem
Why don't you at least try cleaning it before contemplating the replacement.
Re: IACV Problem
Originally Posted by grumblemarc
(Post 46836903)
Why don't you at least try cleaning it before you contemplating the replacement.
Re: IACV Problem
Took it off and tried cleaning with carb clean with no change
Re: IACV Problem
Retrieve trouble codes if any.
Re: IACV Problem
No trouble codes at all
Re: IACV Problem
if you cover the whole t/b does the car die ? check throttle cable adjustment ,idle air bleed screw, and throttle stop(do not adjust this) if there all ok replace iacv
Re: IACV Problem
Originally Posted by ek.troy
(Post 46836889)
Re: IACV Problem
Originally Posted by canadaek
(Post 46840586)
Originally Posted by RonJ@HT
(Post 46841176)
What CEL codes are thrown? Does the CEL work? This could be caused by a dirty IACV or also by a faulty ECT sensor or TPS.
Re: High idle when IACV plugged in
ttt
your iac is done go get a new one
Re: IACV Problem
Originally Posted by Libertariat
(Post 46836981)
Remove the IACV, take it apart and clean it.
I am using B12 Chemtool Carb cleaner I will try taking it apart and trying again.
