car gains tha same in 5th then if i down shift to 4th?
Old Feb 9, 2012 | 10:02 PM
Dead CIVIC's Avatar
Veteran: Army
Default car gains tha same in 5th then if i down shift to 4th?
si i have a GSR chipped ECU [skunk2 intake] with a ITR LSD trans.
I've been noticing that when I'm in 5th gear [4800RPM 80MPH] the car gains really good [to 90MPH ] at like 40% throttle.
but if i where to down shift to WOT fourth [5800RPM 80MPG] it gains just the same [to 90MPH] as if i were in 5th at 40% throttle...? why is this?
I tracked it today from 80MPH to 90MPH 5ht and 4th
Old Feb 10, 2012 | 03:07 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: car gains tha same in 5th then if i down shift to 4th?
no one huh?
Old Feb 10, 2012 | 03:21 PM
serversurfer's Avatar
Are you asking why your 80-90 MPH times are the same whether you're in 4th or 5th gear?
Old Feb 10, 2012 | 03:25 PM
Dead CIVIC's Avatar
Veteran: Army
yes. I am wondering why 80-90 gain is the same in 4th at high RPM as it is in 5th gear at a lower RPM.
Old Feb 10, 2012 | 03:31 PM
I suspect your engine output from 4800 to 5400 RPM is similar to your output from 5800 to 6500 RPM.
Old Feb 10, 2012 | 06:23 PM
Gsrsi's Avatar
Throw they skunk2 Mani away it makes your torque suck big d. I had the same problem. Plus u should be at 60 and down shift to 3rd to get a jump.4th and 5th aren't "racing gears"
Old Feb 10, 2012 | 08:11 PM
Dead CIVIC's Avatar
Veteran: Army
seversurfer
prolly right
Gsrsi
i can do that but damn i dont wanna deal with all them vac lines and having to figure out how to make it work i my EM1... I got the engine so I read up about having to chip the ECU and did so... its ok i guess
b_ron
Jul 28, 2011 08:51 PM
CivicUtah
11
Oct 2, 2007 04:04 PM
spiderseth
Nov 10, 2004 04:17 PM
illusion
Jan 17, 2002 07:48 PM
B2FiNiTY
Nov 30, 2001 11:02 AM
