IN NEED OF A GOOD OIL PAN
Old Feb 9, 2012 | 07:56 PM
myessay's Avatar
Icon3 IN NEED OF A GOOD OIL PAN
does anyone know where i can find a aftermarket d16z6 oil pan that is drilled for the drain already? Let me know of brands if u know of any i looked on moroso oil pans couldnt find any for a d16
Old Feb 10, 2012 | 04:11 AM
Slacker93eg's Avatar
10 Year Member
Default Re: IN NEED OF A GOOD OIL PAN
Google is your best friend.
http://www.go-autoworks-store.com/morosooilpans.html
Old Feb 10, 2012 | 05:44 AM
Turbo-LS's Avatar
Why not just bolt a flange or have a bung welded to your free stock pan ?
Old Feb 10, 2012 | 05:51 AM
Orpheus's Avatar
Much cheaper to just get your current pan welded......
Old Feb 10, 2012 | 05:52 AM
kbouchard1092's Avatar
Moroso makes a good replacement pan with fittings for turbo return , and oil tempature sensor.
HOwever i am having issues with the pan leaking. the tray they spot weld in to keep oil from leaving the oil pick-up area during hard cornering (baffle plate? forget the name) Well they spot weld it in about half way up on the pan and its leaking at 4 of maybe 9 of the spot welds....been using hondabond as a temporary fix. Which has actually held up really well.
Old Feb 10, 2012 | 04:08 PM
[Ennis_D]'s Avatar
The Moroso pans will leak. Something that has been covered over and over. RLZ took a bolt on AN return fitting and drilled a hole the same size as the opening on the fitting, two holes for the bolts and bolted it up. I put hondabond between it and the pan and never had a problem out of it. Yes, ghetto but this is what I was given in return for paying for the service and providing a weld-on AN fitting...
Old Feb 10, 2012 | 04:22 PM
10 Year Member
Not to hijack, but I just bought a moroso oilpan, you're saying it will leak from the return line fitting? No big deal but I'd like to know where I have to put hondabond before I install everything.
JdmMidWest
Feb 20, 2012 05:20 PM
discrete
Mar 27, 2005 04:58 PM
fandango
Jan 20, 2005 06:20 PM
Surreal
Mar 9, 2004 06:49 PM
