96 civic ex with dome light/electrical issue not working
Old Feb 9, 2012 | 03:10 PM
deving916's Avatar
Default 96 civic ex with dome light/electrical issue not working
Hello,
I just picked up a 96 civic ex. The PO had a hack job for the radio wiring, so I picked up a harness and got the radio to work.
My dome light isn't working, was previously working only with the ON position, but now it won't work at all. This morning when it only worked with the ON position, i tried the light green/red and light green/black wires but that didn't work. (is it lg/r to lg/r & lg/b to lg/b or do you do lg/r to lg/b?)
My climate control also doesn't light up, (replaced it this AM, but not sure if it works)
I checked every fuse with a test light and they all work, and the ones that didn't light up I doubled checked.
What should I do now? I checked the fuses underneath the hood as well, still no luck.
I have power to both sides of the dome light (checked with test light), no matter what the switch is on. I also used another bulb but that didn't work either.
Thanks for the help.
Old Feb 9, 2012 | 03:11 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 96 civic ex with dome light/electrical issue not working
Anything wired to the dimmer? Every time someone posts something like this someone has always tapped/hacked into the dimmer switch.
Old Feb 9, 2012 | 03:18 PM
deving916's Avatar
I'll go check, but I've used the dimmer switch before and it works properly.
My dome light was working with the ON position and now it's not at all.
Old Feb 9, 2012 | 03:24 PM
The Grumpiest
Check fuses.
deving916's Avatar
Dimmer Switch works perfectly, and isn't hacked up at all.
I stated in the post that I checked all the fuses, both sides, with a test light.
Also did the fuses under the hood as well.
The Grumpiest
Nevermind. Dumb question. Does the bulb work?
Old Feb 9, 2012 | 03:26 PM
deving916's Avatar
I believe so, I tired alternating two different bulbs, one of which I KNOW worked.
The fuse link or whatever is still good in the bulbs
Old Feb 9, 2012 | 04:43 PM
deving916's Avatar
re-wired the green/red to the green/black and i got the dome light to work in the middle position, just not the ON position.
also fixed the climate control lights (forgot to plug the green plug back in, oops!)
Old Feb 9, 2012 | 05:22 PM
NVturbo's Avatar
O.G. triple O.G.
The stock radio had the domelight wiring wired internally into it. Google "96-98 Civic domelight issue".
Here you go...enjoy:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-96-98-civic-dome-light-fix-after-installing-aftermarket-radio-2214962/
Old Feb 9, 2012 | 05:55 PM
deving916's Avatar
yeah i read that already, thanks.
I got it figured out. I had the dome light hanging so once i put it back up it was grounded so now everything works.
had to cut the g/r wire and jump it to the g/b wire.
thanks for all the help
edgargqv
Honda CR-V & Element
Feb 12, 2016 09:48 PM
Destin1
Feb 3, 2012 11:41 AM
JDM_SOHC
Mar 2, 2008 12:54 PM
bullets
Aug 24, 2006 12:51 PM
