1996 Civic EX. Cruise Control Problem.
The cruise control turns itself off. The light will come on and it seems to work, but it will not work long. Often you can try to turn it on and the dash light will not come on and the switches have no effect. Can I replace a switch or a fuse to fix this?
Re: 1996 Civic EX. Cruise Control Problem.
When you press the cruise control button on the left dash, the green light in the button should illuminate. When cruise turns off, does the button light turn off also?
No, the light on the button does not work or I have not noticed it. All I noticed was the light in the instrument cluster. It came on and it worked for a few miles then cut off and would not come back on.
Oh look, I can change this
Dashboard switch/button light may be burnt out (even though this is unlikely), so this is not a sure-fire way of diagnosing the problem. For starters, swap the bulb with a known good then post back here whether it turns Green when you engage it with the car ON.
skater4life3168
07-25-2017 11:28 AM
windriver10
06-11-2010 11:51 AM
chadecoen
08-24-2009 04:30 PM
