would a honda civic 2000 start without oil?
Old Feb 9, 2012 | 02:55 PM
miatech's Avatar
Default would a honda civic 2000 start without oil?
I have a honda civic 2000 and it will not start. I can hear the starter trying to turn the engine over, but it wont start. I gave it a jumper, still same won't start. I think it might be either the sparks plugs or the distributor(maybe both). But I notice that it had very little oil in the dipstick... do you guys know if an engine without oil would prevent it from start?
Thanks
Old Feb 9, 2012 | 03:01 PM
grumblemarc's Avatar
The Grumpiest
Default Re: would a honda civic 2000 start without oil?
Obviously it has oil and the car will start with low oil. Even near to no oil. Your title is misleading. Your no-start has nothing to do with the low oil.
Old Feb 9, 2012 | 03:02 PM
sde780's Avatar
If the motor seized from lack of oil it may not start, but I doubt that's your problem.
Old Feb 9, 2012 | 03:06 PM
The Grumpiest
Is the engine trying to turn over?
Old Feb 9, 2012 | 03:09 PM
miatech's Avatar
yes, the engine is trying to turn over.... I can see the timing belt moving
Old Feb 9, 2012 | 03:10 PM
The Grumpiest
Are you getting spark? Fuel pump priming? Can you push start it? Battery weak? Any CELs?
Old Feb 9, 2012 | 03:29 PM
miatech's Avatar
I tried push start it, and didn't work.... as far as the others things I don't know how to check for sparks; however, I opened a tap on top of the motor and I can see the pistons go up and down
Old Feb 9, 2012 | 04:18 PM
miatech's Avatar
so I guess that the answer to the question whether the engine can start without oils is "YES" so I can discard the problem is no oil... yes I know I need to put oil in the car before I do anything else
Old Feb 9, 2012 | 04:26 PM
The Grumpiest
This is from the FAQs.
ruckusheights
Honda Ruckus and Scooters
Aug 8, 2018 03:41 PM
Kyrus
17
Sep 2, 2016 08:19 PM
toyonda
10
Feb 22, 2012 05:35 PM
antig24
Sep 3, 2010 12:13 PM
TecHMec
Jan 31, 2006 06:00 PM
