D15B7 wont rev past 3k rpms!! im stumped!
Old Feb 9, 2012 | 11:46 AM
sethmoman's Avatar
Icon2 D15B7 wont rev past 3k rpms!! im stumped!
OK i have a 93 civic lx d15b7 5 spd. i can start the car up fine. it will idle fine and get to normal running temp.
Problem.. When i rev the engine up it hits 3k rpms sometimes 3.5k and then bounces down to 0 and stalls out the car.
i have heard backfires maybe 2 or 3.
what has been replaced:
vacuum lines
rotor and cap
ignition module
ignition coil Please Help!! thanks in advance
fuel pump for viewing.
fuel filter
spark plugs
wires
throttle body gasket
exhaust manifold gasket
Old Feb 9, 2012 | 11:58 AM
grumblemarc's Avatar
The Grumpiest
Default Re: D15B7 wont rev past 3k rpms!! im stumped!
Again. CELs? Does the CEL even work?
Old Feb 9, 2012 | 03:15 PM
adgjler's Avatar
vacuum lines
rotor and cap
ignition module
fuel filter
spark plugs
wires
have you tryed the tp sensor and the map sensor wires they have the same plug and may be hooked up backwards happend to me before
Old Feb 10, 2012 | 09:00 PM
sethmoman's Avatar
no cels, and yes it works. im so lost i just want to get it working properly again.
Old Feb 10, 2012 | 09:04 PM
sethmoman's Avatar
hey i have no cels. i just wanted to talk with you seeing as how you seem to be on most. in reference to the d15b7 post about rpms not going past 3k and the car stalling
Old Feb 11, 2012 | 05:01 AM
Former User's Avatar
Check the mechanical timing. It may be off by a tooth.
Old Feb 13, 2012 | 09:18 AM
adgjler's Avatar
have you tryed the tp sensor and the map sensor wires they are right in the intake mani they have the same plug and may be hooked up backwards happend to me before
CaptRexKramer
Nov 10, 2014 01:13 PM
sethmoman
Feb 7, 2012 10:13 AM
sethmoman
Jan 11, 2012 05:54 AM
Eman48
Nov 9, 2010 04:59 PM
quick87crxsi
Dec 19, 2006 05:22 PM
