D15B7 wont rev past 3k rpms!! im stumped!
OK i have a 93 civic lx d15b7 5 spd. i can start the car up fine. it will idle fine and get to normal running temp.
Problem.. When i rev the engine up it hits 3k rpms sometimes 3.5k and then bounces down to 0 and stalls out the car. i have heard backfires maybe 2 or 3. what has been replaced: vacuum lines rotor and cap ignition module ignition coil Please Help!! thanks in advance fuel pump for viewing. fuel filter spark plugs wires throttle body gasket exhaust manifold gasket |
Re: D15B7 wont rev past 3k rpms!! im stumped!
Again. CELs? Does the CEL even work?
Originally Posted by sethmoman
(Post 46832162)
no cels, and yes it works. im so lost i just want to get it working properly again.
hey i have no cels. i just wanted to talk with you seeing as how you seem to be on most. in reference to the d15b7 post about rpms not going past 3k and the car stalling
Check the mechanical timing. It may be off by a tooth.
http://i639.photobucket.com/albums/u...cture_3576.jpg |
have you tryed the tp sensor and the map sensor wires they are right in the intake mani they have the same plug and may be hooked up backwards happend to me before
