very soft brakes
Hey guys I just started driving my 92 eg hatch again after I re-soldered the main relay. Yesterday I noticed the brakes are extremely mushy and ineffective. I've never driven a car that had a failing master cylinder but it feels like there's no brake fluid (but there is).
IDK how relevant all these are but here are its symptoms:
-soft pedal, barely does anything until last 1/10 of press
-can lock up LEFT ONLY side tire, car pulls to right
-fluid level unchanged
Try bleeding the brakes. You need to go right-rear, left-front, left-rear, right-front.
Did this happen all of a sudden? You may have sprung a leak somewhere, perhaps at the right-front. Do either or both of the rear brakes engage?
It was simply this.
The car pretty much just sat for the last year so the indictator on the pad was gone. The pads were at least 6 years old (they looked 12 years old lol) since I've owned the car that long and never changed them (only put like 14k on the car total).
They were so low the left caliper warped itself from the bracket and I need a new one.
I seem to be having this same problem, but when i go to stop i pump it and it seems to regain pressure.. my brakes are fully bleed, the only thing i recall is removing them off the carrier when swapping out my ball joints, i am a little confused as well.. i think the caliper might be going or master cylinder.
Did you even narrow down what it could be or did you just ask a blind question........ If your pads are low replace them, If your rotors are warped have the turned or replace them, bleed the system, check brake booster, and lastly check master cylinder. Notspecifically in that order but thats about it, if your brake fluid level is the same it may not be a leak but double check just to be sure.
im having the same issue, but im not sure how to bleed the brakes for the rear, especially they are drum brakes.
I found these diagrams but im not sure if its even right
http://www.hondapartsnow.com/Page_Pr...e=Rear%20Brake
any help would be appreciated.
Here are complete Honda Parts catalog and diagrams on www.hondapartsnow.com
With out a doubt new rotors and pads front and rear If there still soft bleed them if it's still goes soft but pumps up its the master cylinder it's rare to be booster but typically the first three things will take care of any prob
If you go in to AutoZone, you can buy a brake bleed kit for like $9. It's basically a couple of hoses and a vacuum bottle. You hook one end of the hose to the bleed screw, and the other end to the bottle, open the screw, pump the brakes until there are no air bubbles coming out of the screw in to the hose, and then tighten the screw. I think it's called a "One-man Brake Bleed Kit" because the vacuum bottle prevents you from needing to close the screw before releasing the brake pedal, but it's nice to have an assistant who can watch for bubbles while you pump the brakes.
Be sure to keep the bottle higher than the bleed screw — it comes with a little magnet — and make sure you keep the master cylinder topped up with fluid so you don't reintroduce air at the head of the system.
Vagitarian
23
May 8, 2013 09:38 AM
Mentasti
Sep 30, 2006 03:37 PM
RTE117
Aug 25, 2005 11:09 AM
