93 civic lx d15b7 - rpms jump around and stalls when i give it gas
ok so i have a d15b7 5 spd. my car broke down and i got it running but it still has some wierd issue that i havent been able to identify. much help would be appreciated. basically i can start the car and it will idle fine. when i give it gas it wants to make the rpms jump around and occasionally stall out. here is a list of whats been replaced
all within 1-2 months ago
fuel filter/pump
spark plugs
ignition coil
ignition module
vacuum lines
throttle body gasket
map sensor
please any info would be great i want the 32 mpg back
fuel filter/pump
spark plugs
ignition coil
ignition module
vacuum lines
map sensor
fuel filter/pump
spark plugs
ignition coil
ignition module
vacuum lines
map sensor
fuel filter/pump
spark plugs
ignition coil
ignition module
vacuum lines
map sensor
ok so no cels. and when i said broke down as in the
cars rpms began to fluctuate and when i gave the car gas it stalled out. it would start up and idle fine but when i tried to accelerate it began to fluctuate again and stall out. over and over.
sethmoman
Feb 13, 2012 09:18 AM
sethmoman
Jan 11, 2012 08:44 AM
sethmoman
Jan 11, 2012 05:54 AM
sethmoman
Jan 9, 2012 01:41 PM
