Poly inserts = wicked vibration.
Old Feb 5, 2012 | 11:20 AM
maxspeed96ct's Avatar
Default Poly inserts = wicked vibration.
I purchsed the set of poly motor mount insert for the rear , left and right motor mounts. I read alot of theads about window weld and etc but these were cheap so I figured why bother.
Well the inserts arrived in the mail I was nervous right away since they were rock hard.
Well today I installed the passanger and rear inserts. And the vibration made my brain rattle. I ended up removing both passanger side inserts , and I removed one of the two rear inserts. But there is still a very noticeable amount of vibation.
This is no race rig, just a daily.
If anyone has window weld mounts or something similar. Please give me some details on the softness of the mount and if you have any vibration .
Old Feb 5, 2012 | 11:44 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Poly inserts = wicked vibration.
Window weld is not soft.
Old Feb 5, 2012 | 01:04 PM
k , i've never felt in person. But the poly inserts are pretty much rock hard. A buddy of mine said GEO-GEL is a good filler that isnt rock hard.
do I have any other options?
Or should I try to remove the rear mount insert and leave just the side inserts ?
Old Feb 5, 2012 | 01:07 PM
The Grumpiest
Is there something wrong with the stock mounts?
Old Feb 5, 2012 | 01:10 PM
Nope , I get alittle chatter during take off. I was hopping better /stiffer mounts would help.
And they did , but not I have a wicked vibration which is much worse then the chatter.
Old Feb 5, 2012 | 02:31 PM
NOFX's Avatar
H-T White Ops
Stiffer/harder mounts will give you more vibration.
I have poly bushings in the rear of my Civic. Not comfortable, but they came with the rear trailing arms.
My CRX has stock trailing arm bushings and it drives great! I will never go with poly for a daily especially.
Old Feb 5, 2012 | 03:22 PM
jmai86's Avatar
Simply no way you can get better performance AND a comfy ride in this respect. Poly bushings remain on the track.
Get new oem mounts.
Old Feb 5, 2012 | 03:27 PM
The Grumpiest
Hardrace mounts. Hard rubber (75a). Stiffer than stock with far less vibration than poly mounts/inserts. Been running these for 5 years now.
efyou
Apr 23, 2008 03:59 PM
nick91civicsi
Apr 6, 2008 07:59 PM
Spectrum24x
Jul 6, 2005 10:34 PM
onyx00
Sep 24, 2004 01:00 PM
TypeRuz
Feb 7, 2004 10:04 PM
