Question
i want to lube up my rubber,bushing n ect parts on my suspension. but im not sure which one to buy.. i hear that W-40 is good but then i heard that it washes of after it rains. help me out thanks
White lithium grease is a good choice if you want something in a spray application. If the squeak continues after spraying it with white lithium the part will most likely need replacement.
white lithium spray would work i'm sure. i usually save that for metal to metal or metal to plastic contact like hinges and latches. I use silicone spray on all rubber peices. it seems to actually condition the rubber to some degree. it should stop the squeaks too.
silicone spray... made by different companies ; just go to the auto section, even at walmart
good for door weatherstrips is the main thing i buy this can for,
but didn't know it's to check/isolate squeaks or squeals as well
silicone grease is good as well for dis-assembly
source: http://www.freewebs.com/hondadude/Sw...20bushings.htm
graveltravel2
11
Feb 21, 2007 03:43 AM
