Question
Old Feb 1, 2012 | 05:53 PM
William1991b's Avatar
Default Question
i want to lube up my rubber,bushing n ect parts on my suspension. but im not sure which one to buy.. i hear that W-40 is good but then i heard that it washes of after it rains. help me out thanks
Old Feb 1, 2012 | 07:02 PM
nus_dogg's Avatar
Default Re: Question
Why do you want to lube it? WD-40 won't lube it, its made to break down rusty bolts, etc.
Old Feb 2, 2012 | 03:17 AM
Squeak sound
Old Feb 2, 2012 | 05:00 AM
StreetsideStig's Avatar
It might need replacing.
Old Feb 2, 2012 | 07:41 AM
GhostAccord's Avatar
White lithium grease is a good choice if you want something in a spray application. If the squeak continues after spraying it with white lithium the part will most likely need replacement.
Old Feb 2, 2012 | 08:39 AM
That what I'm trying to do I want to spray it n if it stops I would know what to fix.
Old Feb 2, 2012 | 08:53 AM
hondamark35's Avatar
white lithium spray would work i'm sure. i usually save that for metal to metal or metal to plastic contact like hinges and latches. I use silicone spray on all rubber peices. it seems to actually condition the rubber to some degree. it should stop the squeaks too.
Old Feb 2, 2012 | 12:09 PM
I heard that AT-205 is the best but I can't find it at auto shop . I need something like water proof and help the rubber parts. Ill try looking for white lithium spray
Old Feb 2, 2012 | 07:33 PM
Roader's Avatar
Silicone grease:
Home Depot:
DANCO
0.5 oz. Silicone Faucet Grease
Model 88693
$3.37
Old Feb 3, 2012 | 10:54 AM
Originally Posted by Roader
Silicone grease:
Home Depot:
DANCO
Model 88693
$3.37
So I got some n it so little but I'm try it tonight n see what happens
Old Feb 4, 2012 | 06:14 PM
ricebike's Avatar
better to buy it in aerosol form if you're not going to disassemble and lube each part
Old Feb 4, 2012 | 07:01 PM
What a spray is that? N where can I get it?
Old Feb 4, 2012 | 07:24 PM
ricebike's Avatar
silicone spray... made by different companies ; just go to the auto section, even at walmart
good for door weatherstrips is the main thing i buy this can for,
but didn't know it's to check/isolate squeaks or squeals as well
silicone grease is good as well for dis-assembly
source: http://www.freewebs.com/hondadude/Sw...20bushings.htm
panchlow
Oct 27, 2011 05:45 PM
graveltravel2
11
Feb 21, 2007 03:43 AM
awwsnap
Aug 15, 2005 11:15 PM
soloIntegra
May 12, 2003 12:32 PM
