Codes 1 & 12 Both Are New. ?MAP Sensor or ECU?
Old Feb 1, 2012 | 05:54 AM
roozoo's Avatar
Default Codes 1 & 12 Both Are New. ?MAP Sensor or ECU?
I have a 93 Prelude with Auto Trans and h22a conversion. The car was originally an (SI) H23. I am getting a CEL codes 1 (O2) and 12 (EGR). Both systems are new including O2 Sensor, EGR Valve & EGR Solenoid. All vacuum lines have been replaced. When this happens it gets kind like a misfire of sorts, lacks power and kinda bogs down. This happens every time I drive it. It is not only on occasion. When I turn car off and back on the CEL is off until I drive and get up to around 2000 to 3000 rpm. Then the light is back on.
I have already cleaned the EGR ports. Took the intake completely off, cleaned it inside (removing EGR port plugs) and out to new looking condition. Same as new intake.
I have seen some info around on some ecus where you may have to swap A6 and A11 wires (think it is an Accord thing). I have ecu 37820-P13-900 and all wires look intact (uncut) other than the 2 vtec wires which works fine now. I was wondering if maybe the MAP sensor could cause these symptoms and not throw a code of its own? Maybe a bad ECU? Any other suggestions?
Old Feb 1, 2012 | 07:23 AM
Apex1972's Avatar
Default Re: Codes 1 & 12 Both Are New. ?MAP Sensor or ECU?
take it to a shop
take it to a shop
take it to a shop
Old Feb 1, 2012 | 12:24 PM
roozoo's Avatar
If you are not going to be helpful then keep your comments to yourself.
With that said, the guy i bought the car from had already taken it to several shops none of which had any clue on what was going on.
Old Feb 1, 2012 | 04:37 PM
nemesis25's Avatar
If you have electronic skills, pull the ECU and remove the cover. Inspect for burnt and cracked terminals/components on the ECU board. Hope this helps. Also, trace the wires back to the ECU.
turbohx97
Apr 26, 2008 08:36 PM
b16jaf
Nov 28, 2007 12:07 PM
sohctodohc
12
Nov 9, 2007 12:37 PM
SOHCex20
15
Oct 2, 2005 12:36 AM
Leisyman
May 6, 2003 09:35 AM
