CEL Codes
CEL Codes
Can anyone send me a list of ecu codes for an OBD1 P28 Ecu? D16Z6 engine has just been rewired after someone else's butcher job and need to troubleshoot using the codes. Also need to know where to activate the code data output so I can read them with the CEL
Thanks
Thanks
Re: CEL Codes (Leisyman)
CEL? Are you refering to the MIL codes?
if so, above the ecu there is a green rubber thingy. (kinda technical eh?)
there may be one or two plugs inside of it... (one will have 2 wires, the other 3)
get the one with the two wires and jump them together with a piece of wire,
turn the key over and it will flash your check engine light....
long flash = 10
short = 1
1 Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B"
3 MAP Sensor (Manifold Absolute Pressure)
4 CKP Sensor (Crankshaft Position Sensor)
5 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
6 ECT Sensor (Engine Coolant Temperature)
7 TP Sensor (Throttle Position)
8 TDC Sensor (Top Dead Center)
9* CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10 IAT Sensor (Intake Air Temperature)
12 EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13 BARO Sensor (Atmospheric Pressure)
14 IAC Valve (Idle Air Control)
15 Ignition Output Signal
missing or defective ignition output signal
16 Fuel Injector System
defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor)
19 Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector
21* VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
22* VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23 KS (Knock Sensor)
* not a valid code if V-6 engine
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
* not a valid code for 1996
31 Automatic Transmission Signal "B"
41 Primary Oxygen Sensor - Heater
circuit malfunction
43 Fuel Supply System
defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48 LAF Sensor (Lean Air Fuel)
54 CKF Sensor (Crankshaft Speed Fluctuation)
58 TDC Sensor 2 (Top Dead Center)
61 Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63 Oxygen Sensor, Heated - Sensor 2 (Secondary)
65 Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70 Automatic Transmission
malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire
73 Cylinder 3 Misfire or a Random Misfire
74 Cylinder 4 Misfire or a Random Misfire
75 Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
76 Cylinder 6 Misfire or a Random Misfire
80 Exhaust Gas Recirculation
insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90 Evaporative Emission Control System
leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor
low input
92 Evaporative Emission Control System
insufficient purge flow
Now if theres any other code besides that.. haha your ecu is screw'd for the most part
long flash = 10
short = 1
2 Oxygen Sensor "B"
circuit malfunction
low input
Re: CEL Codes (96exb20)
Thanks to everyone who provided info. found the troubles, i.e.MAP sensor and VSS, now just have to figure out what is causing it.
MAP should be fairly simple, but.....
There is no wire in the dash harness I can find which will wire to the ecu for the VSS. Speedo needle jumps around wildly under acceleration.
Any ideas?
[Modified by Leisyman, 6:31 AM 4/9/2002]
Any ideas?
ALL CLEAR!
Thanks to everyone for the help!. No codes, engine runs great!. Now I have to find a cat convertor, as someone cut out the cat and put in a glasspack. Can't pass Colorado emissions visual inspection without a cat.
anyone have one they want to part with?
Junkyards can't sell them for legal reasons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leisyman »</TD></TR><TR><TD CLASS="quote">ALL CLEAR!
just go to an exhaust shop and have them weld an aftermarket one on...
should not be a problem...
sh!ft
05-13-2009 01:18 PM
