d15b vtec rpms
Assuming it's stock, if you have the P08 ECU, your VTEC switch is at 4800RPM. If you have the P2J ECU, your first switch is at 3000, and your second switch is at 6000.
Seriously though, at least make an effort to find information on your own before you ask. "D15B" in Google leads directly to the wikipedia article that gives this information.
It's not the OEM pairing, but it should work just fine. Assuming it hasn't been modified, your VTEC cross is at ~5000. Once again, information I found on that same Wiki article.
If your car is obnoxiously loud, its likely you won't hear the crossover. Exhaust side doesn't take change in tone for a sohc. Intake side would be where its heard if you're really looking for it.
Addicted2Racing
10
Jan 27, 2004 04:29 PM
