new car, need Synapse help.
Old Jan 30, 2012 | 12:34 PM
stangsgt83's Avatar
Default new car, need Synapse help.
I just purchased a 93 civic hatch with a new motor built by Synapse B16 long block. Skunk 2 cams. Its NA high compression and 243hp im told. the car doesn't have a tachometer and i'm not sure how high i can rev the motor without red lining. Motor has less than 5 miles on it. I have a Neptune RTP and bigger injectors waiting for spring. current set up is stock injectors and intake. Any help is greatly appreciated.
Old Jan 30, 2012 | 12:39 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: new car, need Synapse help.
8600 is certainly safe, see where the power dips off. and quit reving.
Wouldn't be a bad idea to program in a rev limiter. Red lining and rev limiting are not the same thing.
Old Jan 30, 2012 | 01:14 PM
Dc4LsTeG's Avatar
EK9
You should definitely get a tach
Old Jan 30, 2012 | 01:21 PM
stangsgt83's Avatar
any suggestions on intakes for a hot NA b16. it has a 70mm bbk throttle body.
Old Jan 30, 2012 | 01:24 PM
Dc4LsTeG's Avatar
EK9
Something 3"
stangsgt83's Avatar
im looking for a dash cluster with tach. im trying for the stealth look.
Old Jan 30, 2012 | 01:28 PM
Dc4LsTeG's Avatar
EK9
Ok when I said get a tach that's what I meant even though OEM tachs aren't super accurate
Driveshaft
Apr 18, 2011 11:31 AM
myke
Jul 20, 2004 07:49 PM
jdmspec1122
13
Mar 21, 2004 12:49 AM
ActiveAero
Jan 11, 2004 02:56 AM
Arsenal
Feb 10, 2003 11:29 AM
