91 civic HB big turbo build
I have a 91 HB that i am building. my engine is a B18A1 I need advice on what turbo i should use and fuel system.
B18A1 block:
Darton sleeves bored to 2.1Liter
Crower stroker kit 92mm stroke 85mm bore
CP puck style Pistons 9.0:1
Carrillo H beam rods
Crower crank entire rotating assembly balanced to 1/100th of a gram
acl bearings
CTR crank pully
ITR oil pump
Morosa oil pan
entire bottom end WPC treated
competition clutch twin disc
PR4 head:
full port and polish
crower dual spring and titanium retainer kit (WPC treated)
crower stage 2 turbo cam shafts (WPC treated)
crower stainless steel 31mm intake and exhuast valves
buddy club cam gears
greddy timing belt
super tech bronze valve guides
edelbrock intake manifold
70mm throttle body
any other advice would be greatly appreaciated and advice on a good fuel setup and turbo setup would be great. im looking into 35R, precision 6265, or precision 6262. my hp goals are in the high 600 range but 700+ would be amazing
B18A1 block:
acl bearings
CTR crank pully
ITR oil pump
Morosa oil pan
PR4 head:
greddy timing belt
70mm throttle body
ExplicitSpeed
Apr 6, 2004 11:30 PM
ExplicitSpeed
Mar 8, 2004 10:59 PM
