steering wheel not straight after alignment
ok so my wheel is off by probally 5 degrees when driving straight its a little to the left.. i just had gotten an alignment.. from what i understand the alignment only does the toe/camber.. so how can i fix this
You have started two threads about this already and NEVER followed anyone's advice ONCE. Why do you feel the need to start another?
Reported for spam.
Reported for spam.
Unless you have an aftermarket camber kit you can only adjust toe on a Honda. I remember your other threads, if you are having problems with the wheel returning to center on it's own then you will need to sort that out out (it's often do to seized lower ball joints) if it returning to center properly but the wheel isn't centered than you need to take it back to the alignment shop and center the wheel.
I'm leaving this open, but please stop creating essentially the same thread over and over asking for advice and then not taking it.
No they aren't supposed to do anything but the alignment. Conscientious shops will go the extra mile and to it automatically like the one I go to. Most shops will take of the alignment and that's it unless you tell them to straighten out the wheel when you bring it in. In this case we're talking about a stinking 5 degrees! Do you know how insignificant that is? Even if they would have fixed it they probably didn't even notice it.
So the question is "How can you fix it?" You can't.
A good shop would adjust both sides to get the toe corrected.
grumblemarc is wrong, you can fix it yourself. You just have to take the steering wheel off and recenter it. Not the ideal fix, but for such a small amount...meh.
If you take the wheel off, you have to either disconnect the battery and disconnect the wire for the air bag and then reconnect the air bag before connecting the battery, and possibly have to reset the SRS system, or hang the hang the bag so it doesn't disconnect. There is a risk of the bag going off if it's disconnected while the battery is connected. .
And no, nobody asked, but this is relevant because it relates to how it can be fixed....
ok first of all this is a totally different problem.. im not talking about anything to do with turning the wheel.. i said when i drive straight my wheel is a little to the left.. its pretty signifigent too so i was just wondering since i thought alignment shops only do camber/caster/toe how do you fix this?
yes they are SUPPOSED too it is not the extra mile .. i am a 12 year tech and i have never done an alignment and not at least made an attempt to get it straight ( if there is play in the tie rods you may not be able to but they should at least inform you of this issue ) .. right on the alignment step by step procedure it tells you to center the wheel .. you are supposed to center the wheel every time you do an alignment unless your a lazy ******* that dosnt follow procedure and tries to take the diff out of just one side .. any shop that doesnt at least make an attempt to do this shouldnt be open .. yes they are supposed to .. take it back and bitch ..
Most shops don't have a checklist, I've gotten mine done before and then get told that the suspension needs work AFTER they aligned it, so it won't hold an alignment right as it is currently. I had it where they didn't straighten my wheel. They didn't dial my toe into where I asked. Alignment shops are kind of a sham. It's like getting an oil change and them putting your old filter back on because you didn't explicitly say to replace it...
for anybody else the reads this it's fairly simple to straiten the wheel all you need to do is adjust the toe in the direction the wheel is off . If it's off to the left move both tie rods an equal amount so wheels both move to the left it doesn't take much a 1/16th of a inch will usually fix it or about 1/4 turn make sure its even is the key other wise you screw up the total amount of toe
