diagnose the source of oil in my cylinders
Old Jan 27, 2012 | 05:21 PM
blackeg's Avatar
Default diagnose the source of oil in my cylinders
what do you guys think about this?
ive got oil on the top of one of my pistons as seen through the spark plug hole.
the spark plug is clean no oil
the intake and exhaust ports dont have any oily crud build up
compression is 225psi, all my cyls are between 220 and 225 on a 10:1 engine
leakdown is 8%, all my leakdowns are 6-10%. it is a 500hp engine so my piston to wall and ring gaps are on the big side. all lost air is going into the crankcase as i hear the pitch change when i take off the oil fill cap/dipstick.
what ya think? valveseals? is there any way its left over oil from assembly i might have gotten in there? engine has 3500 miles
Old Jan 27, 2012 | 05:29 PM
2low93's Avatar
Default Re: diagnose the source of oil in my cylinders
More and likely the valveseals are leaking since the oil in on top of the piston. The oil use in the build should have been burned of now or after ur first all change. Was all four piston were around the same psi. Cuz more and likely the one with the oil should have been higher than then other due to oil.
Old Jan 28, 2012 | 05:43 AM
blackeg's Avatar
all 4 cylinders were within 5 psi compression. it wasnt a puddle of oil by any means, but you could see that it was wet like you wiped the piston with a oily rag. that cylinder did have a tad more carbon buildup in it
Old Jan 28, 2012 | 08:26 AM
turbohatch96y7's Avatar
It can be fuel your seeing. Maybe too much fuel in that cylinder. Is it burning oil??
Is this the engine you just had apart??
Ohbebe75
Aug 4, 2010 06:29 AM
Hill4589
Apr 10, 2009 04:56 PM
jakscivic
Jan 31, 2007 06:11 PM
IloveNewt
Dec 21, 2003 10:18 AM
BoM
Aug 12, 2001 11:23 PM
