B16b timing issue
Old Jan 24, 2012 | 07:03 AM
Tim1982's Avatar
Default B16b timing issue
I am stumped and need a little help. I have set my engine to tdc on crank
And lined up my cam pulleys. Now the engine is a ctr b16b in a eg civic running pct
Ecu and a obd1 distributor. (it is not oem) Now my problem is when I try to time it
The engine will stumble under acelaration. There is only one spot I can set it to on the
Whole range of adjustment on the distributor. that spot is almost advanced all the way.
do you guys think it could be my distributor? Thanks in advance for the help.
Old Jan 25, 2012 | 07:28 PM
Dc4LsTeG's Avatar
EK9
Default Re: B16b timing issue
Any cels?are you sure your mechanical timing is correct?
Dc4LsTeG's Avatar
EK9
And what dizzy are you using?
Old Jan 26, 2012 | 07:53 PM
Tim1982's Avatar
Yeah all timing is correct. I just gambled and got a td44 oem distributor
And it runs great now. Thanks for the reply.
Old Jan 26, 2012 | 09:56 PM
Dc4LsTeG's Avatar
EK9
So its fixed?
Old Jan 26, 2012 | 10:08 PM
00_EKHatch's Avatar
IB4TL!!!!
Old Jan 28, 2012 | 08:42 PM
Tim1982's Avatar
Yeah its running great. It had a cheap ebay distributor on the motor when I bought my swap and it was running like crap. So I just got a td44u from a buddy and its cool.
MastaFlyMason
Oct 2, 2016 02:53 PM
tcyprusdc2
Apr 4, 2014 10:05 PM
bnmm
Engine Management and Tuning
May 27, 2011 05:28 AM
Feriofan
Jul 29, 2004 11:27 AM
Hybrid Invasion
Mar 31, 2003 02:35 PM
