2000 Civic Si bogging at low rpm's when warm!
Old Jan 27, 2012 | 12:17 PM
RogerDodgerSi's Avatar
Default 2000 Civic Si bogging at low rpm's when warm!
Hey guys so i recently bought a 00 Si and it was running fine for a while till one day it left me stranded on the freeway, my friend checked it out and determined it was my timing belt. So i got it replaced and timing was correct but was bogging at low rpms!
After adjusting the distributor timing to 12. It seemed to be running perfectly like before, but after a while and at full operating temperature it started to bogg down again at low rpm's in any gear but it eventually picks up after 4000 rpm,
I had a check engine code before the timing belt went out for the second sensor (post cat) i believe, code p0141. I have not replaced it yet but ive read that it shouldnt affect with the bogging?
Will the bad o2 sensor be causing this bogging? Or should i re adjust the timing by tapping into the ecu connection? (i didnt do it in the first place)
Hopefully a full tune up will do the job! Please let me know what you guys think
Old Jan 27, 2012 | 12:19 PM
Gsrsi's Avatar
Default Re: 2000 Civic Si bogging at low rpm's when warm!
A bad cat can make that happen.
Old Jan 27, 2012 | 12:32 PM
Yeah Ill change the o2 sensor and take a look at the cat but it was installed by the previous owner not too long ago.
Old Jan 27, 2012 | 05:57 PM
Gsrsi's Avatar
He could of went to a junk yard and bought a "new" one. I had one of my cars do this. I would let it warm up and once warm it would bog and seem o be running on 2 pistons. It has to do with either ignition or your cat.
Old Feb 24, 2012 | 11:26 AM
Bump
Ok so i got the cat checked out and its still good, i recently got my engine rebuilt, i got my car back yesterday and it still hesitates on acceleration! I still have the CEL P0141 for the secondary o2 sensor, i ordered it already just in case. This is my last conclusion on why its bogging out but i hear that the secondary o2 wont affect the engine with the hesitation? Maybe my plug wires or cap and rotor? Running out of ideas
Old Feb 24, 2012 | 11:38 AM
kyden's Avatar
do you have a single cam in it or a b16? (i can't tell if you're in canada or not)
Old Feb 24, 2012 | 11:46 AM
Yeah stock b16a2
punchodex
19
Jan 3, 2015 03:52 PM
Mustang72
Honda Civic (2001 - 2005)
Dec 1, 2014 08:04 PM
Supahatch
Jul 5, 2005 01:35 PM
CivicMike
Apr 23, 2005 02:48 PM
Gasoline Fumes
Sep 25, 2002 05:28 PM
