stains on rods
Old Jan 26, 2012 | 06:11 PM
hybridmiklo's Avatar
Default stains on rods
I just recently dissasembled my b18 block. Sent it to the machine shop. They cleaned the block, decked it, pressed my pistons on to the rods. They said they all checked out fine. On the rods where the bearings go there are black stains from the previous rod bearings. How to I get those off? I know I cant use anything abrasive so what can I do?
Old Jan 26, 2012 | 08:50 PM
93egSLEEPER's Avatar
Default Re: stains on rods
Leave them.
Old Jan 26, 2012 | 09:21 PM
really? I wont have a problem when I place the bearings on them?
Old Jan 26, 2012 | 09:34 PM
It's a stain...as long as the surface is flat and smooth there will be no issues with it. No one sees under the bearing of your rods connected to the crank under and oil pan Slap dem berings on dere and get dat bitch runin!
Old Jan 27, 2012 | 02:31 AM
wolve's Avatar
stains normally means overheating has occured.
if they checked them for roundness and dimensions, and they checked out fine run it!
if they have'nt checked them, sure do so!!!
Old Jan 27, 2012 | 09:38 AM
q16racer's Avatar
Look on the backside of the bearings and you will likely see the stain a bit more pronounced. This could be an indication of incorrect bearing crush where the bearing did not seat properly in the rod bore. In doing this, oil gets between the bearing and simply gets hot. Much like the internals of an engine whose oil change intervals were too long.
Old Jan 27, 2012 | 12:16 PM
97mm_EH3's Avatar
Scotchbrite pads. Purple in color if possible.
Old Jan 27, 2012 | 05:40 PM
cool. Thanks for the input guys. Much appreciated
1320london
Engine Machining & Assembly
Apr 24, 2017 03:27 PM
90ZCREX
Sep 3, 2011 11:47 PM
iownahatchback
Jan 31, 2010 05:54 PM
kornerk12
12
Jul 21, 2007 08:37 PM
