Problem with neutral safety switch
Old Jan 24, 2012 | 01:04 PM
maddhatter1's Avatar
Default Problem with neutral safety switch
Hi all, I am having a problem starting my 97 lx accord as it was initially only starting in neutral and the key was stuck in the ignition and would not release. Seemed to be an obvious neutral safety switch issue, so I replaced it and now nothing, won't even start in neutral anymore. So I put the old one back in and now it won't start in neutral anymore. In addition, the gear indicator lights on the cluster used to show what gear I was in except when in park, but now they just show D4 and nothing else. When I looked at the switch installed, there is a gap of about an 8th of an inch between the contacts on the switch and the metal spindle that is in there. Should they be touching? I also understand that there is a gear switch too on this model or is it the same as the neutral safety switch? Now I dont know what I did but need to get some ideas of whats going on. It looks like the metal arm has to be making contact with the switch to read it, but dont see why its not touching it, or maybe it just needs to be close? Thanks in advance.
97 Accord LX
Old Jan 25, 2012 | 03:11 PM
Lost Again's Avatar
Default Re: Problem with neutral safety switch
I hope the pic's and suggestions I gave helped....let us know.
Old Jan 30, 2012 | 10:42 AM
It was pretty stupid really....initially I didn't realize that there was a slider on the inside of the nss and that the spindle arm had to be inserted into it. When I installed it the slider had slid to one side and was partially hidden and I didn't see it until I saw the diagram of it and how it worked. Duh! Thanks again.
Old Jan 30, 2012 | 05:21 PM
Lost Again's Avatar
Glad you got it.......
Old Jun 26, 2012 | 03:32 PM
toy8500's Avatar
I am ready to replace a neutral safety switch in a '97 civic dx a/t, any tips and or pics of the procedure would be greatly appreciated.
Old Apr 21, 2021 | 01:54 PM
Seas Garage's Avatar
I too am having an issue with the NSS. I looked through the comments, and seen you guys talked about a diagram, but i cannot find it. Where do i look? Thank you.
Old Apr 21, 2021 | 02:43 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
See attached.
Old Apr 22, 2021 | 12:40 PM
Originally Posted by tech8
See attached.
thanks! So this is what i have to adjust after i put the new nss on the trans?
Old Apr 22, 2021 | 12:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Yes, (1) shifter has to be in Park (P) and; (2) the slider has to also be in the parking position, where the pin is in the switch slider as shown.
Old Apr 25, 2021 | 12:09 PM
ok. So the part with the harness that connects on the outside of the vehicle, behind the front passenger side wheel, doesnt have to be in any certain position as long as its connected and bolted down? And then once that is done, I just follow the diagram?
imzjustplayin
Apr 17, 2008 09:08 AM
b00sted4dr
Jul 31, 2006 05:00 PM
91blksi
Dec 13, 2004 07:29 AM
Redicliff@honda-tech
Nov 28, 2004 06:44 AM
5 watt
Audio / Security / Video
Jul 5, 2002 12:07 PM
