95 civic cx w/t LS swap Early fuel cut problem
Old Jan 22, 2012 | 07:51 PM
MShonda's Avatar
Default 95 civic cx w/t LS swap Early fuel cut problem
Okay iv had this hatch for about 3 months now. Its a completely stock obd1 b18b1 ls swap in a cx and its a p75 ecu.
when i got the car it was revving out to 6500 to what feels like a fuel cut. NO cels.
I pulled the motor out and installed a blox im and skunk2 tb, new clutch and flywheel, header and exhaust. got everything back together and now its only revving out to 6k to what feels like a fuel cut. Im also throwing a code 16 cel.
Any Ideas to what could be causing the early limiter and cel. im stumped
thanks
edit.for code 16 I also replaced the stock fuel pump with a fullblown 340lph unit..
i believe all the injectors are clicking. its def running on all 4 and has a smooth idle.
Old Jan 24, 2012 | 01:37 AM
MShonda's Avatar
Default Re: 95 civic cx w/t LS swap Early fuel cut problem
bump.. anyone?
Old Jan 26, 2012 | 03:02 AM
MrRogers21's Avatar
thanks
Does the fuel cut off bog down the car similar to a slowed red-line bouncing the car forward and back? because my auto does this when I try and floor it.. I haven't found the cure yet for it.
bleedblue94
Apr 13, 2006 02:58 PM
NINE TRE
Jul 12, 2005 10:12 PM
GPwhiteDB8
Oct 16, 2003 06:42 PM
self_made
Jun 5, 2003 09:27 PM
