motor cuts out at wot
just swapped an ls in my friends car and everything is great except that whenever the car is at 100% throttle it cuts out...if the throttle is open 95% its fine. motor runs very strong. i have replaced the plugs and wires opn the car, and the main target i thought for this problem would be the tps. well i rechecked it and its at .5v at idle and 4.41 at wot.
this is an obd1 b18b in a 94 civic
Re: motor cuts out at wot (bleedblue94)
did it through any codes? and when you sy cuts out is it like fuel cut or like something else? al;so what ecu did you put in there?
Fuel pump may play a roll in it.. I mean it dosent sound like the timing is bad. sounds like a sensor but you said that you checked them, and plus theres no codes..hmmm my next guess would be Fuel Pump..
s10cky
02-04-2006 01:15 PM
Jawad.
09-04-2003 12:19 PM
