EF help!! no spark or fuel pump
Old Jan 22, 2012 | 06:27 PM
StayTunedEf's Avatar
Default EF help!! no spark or fuel pump
i recently replaced the head gasket on my d15b7 and in the process i cut the resistor box out and put obd1 injectors in ( i believe the car had obd1 injectors the whole time running with a resistor box) anyway now theres no spark from the spark plugs but the distributor gets power to the coil but doesnt send it any farther and also the fuel pump doesnt kick on, the car has a check engine light but doesnt throw a code?? but ive tested the fuel pump direct to the battery and it kicked on? main relay?? also im not sure the correct wireing for the resistor box what wires are the power? my brother tied them all together and made it one ground. do u think that would of shorted the relay if one is a power wire? plez any help is appreciated
Old Jan 22, 2012 | 06:46 PM
singlecamsaint's Avatar
Default Re: EF help!! no spark or fuel pump
sounds like main relay
Old Jan 22, 2012 | 06:49 PM
think so do u no anything bout a resistor box?
Old Jan 22, 2012 | 07:10 PM
let me look at my notes and get back to you, i cant remember if the injector power comes directly from the main relay or not, its been a minute since i did the swap myself
Old Jan 22, 2012 | 07:45 PM
it looks like it goes from A15 on the ecu to the main relay then out to the injectors...dont quote me though lol just try replacing that relay
Old Jan 24, 2012 | 05:15 PM
got it it was the relay runs like a champ!! :p
Old Jan 24, 2012 | 08:13 PM
they burn out sometimes
Car fan
Sep 27, 2016 10:58 AM
oneslowstd
Nov 25, 2006 02:25 PM
FastAsleep
17
Aug 28, 2006 04:40 PM
Btothe3rdDegree
16
Nov 28, 2004 06:50 AM
13sechatch
Jul 30, 2004 11:21 AM
