no vtec dont know why
Alright got a 93 eg hatch with a gsr now I'm throwing code 20 and its saying eletric load detector. Now I never heard of that before but all my wiring seems to be good from pressure switch and cylinoide to the ecu I checked my engine bay fuse box because that's were I was told the eletric load detector was located and everything looks fine but I still have no vtec I'm running a gsr p72 ecu
Lmk if anyone can give me any other ideas on what can be going wrong here
The easiest thing is try swapping the ecu to a chipped ecu cuz once chipped they can delete the ELD and Also I believe the ELD is in The underhood fuse panel you can swap that or try a different ecu lmk what happens
Yeah I know were the eld is I found a thread saying to check voltage and all that and came out good so imma swap my ecu and fuse box tomorrow and see if that helps
blackEGFTW!
Sep 4, 2009 04:25 AM
