tourque settings for arp eagle rod bolts
Old Jan 18, 2012 | 05:09 PM
x-s-i-v's Avatar
Default tourque settings for arp eagle rod bolts
ive got to drop a piston out to check for dammage etc
the piston looks fine. just want to be sure.
b16a
je pistons
eagle rods
arp rod bolts
i cant remember the tourque setting for the arp rod bolts or the crank cap bolts.
can any one let me know the best way of doing it.
i was just going to undo the rod bolts and push the piston up.(the heads off)
cheers
Old Jan 19, 2012 | 09:32 AM
kbouchard1092's Avatar
Default Re: tourque settings for arp eagle rod bolts
the correct way is using a rod bolt stretch gauge and torque it till you reach the the proper stretch. i want to say the 3/8 " arp is around 46 ft/lbs tho if you dont have the gauge
Old Jan 19, 2012 | 11:14 AM
x-s-i-v's Avatar
i have a tourque wrench to do them up so should be good thanks. can any one alse comfirm 46ft/lbs
Old Jan 19, 2012 | 06:21 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Did you try searching?
092eg6
Mar 30, 2010 12:16 PM
rich7777
Mar 1, 2010 07:43 AM
Wazup
Mar 31, 2005 02:58 PM
turbociv
Sep 8, 2003 05:41 AM
Drag R
Jun 14, 2003 07:54 AM
