Transmission Problems
Old Jan 15, 2012 | 01:28 PM
Sweetfish89's Avatar
Default Transmission Problems
Was driving then heard a loud pop and then clanking noise like I was dragging something. Pulled over and saw nothing under the car. When I turned the car back on I could not get it into gear so I turned the car off and wiggled the shifted then turned the car back on. When I started it, I got it into third but when I rolled forward I heard a knocking/clicking noise every full revolution of the wheel so I stopped and could not get the car to stay on while the shifted was in neutral. I turned off the car. checked granny fluid, was a little low so I filled it up. Still will only move in third gear and knock/clicks.
I was at a red light, when it turned green I was in first gear got half way through the light when this happened.
1990 Civic with 1990 I believe 5 speed sedan transmission
Old Jan 15, 2012 | 01:41 PM
alex14's Avatar
Default Re: Stuck on the road
check your axels, make sure lugs are tight, make sure your shift linkage is hooked up right.
Old Jan 16, 2012 | 08:09 AM
Axles are all snug in place, lugs are nice and tight, linkage has not been messed with since I got the car two years ago. But it looked fine when I climbed under the car.
Old Jan 16, 2012 | 08:27 AM
90civic-ZC's Avatar
Is your problem now getting it started or getting it in? Does it grind putting it in any gear besides third?
Old Jan 16, 2012 | 10:10 AM
No, the car starts and runs fine. I just cannot get it into any gear other than third. It does not grind it just wont go into gear.
Old Jan 16, 2012 | 10:38 AM
90civic-ZC's Avatar
Sounds as if the shifting linkages are messed up or something in your tranny broke off. If you heard a pop and grinding sound, that's no good.
Old Jan 16, 2012 | 12:19 PM
When I go back home, I will have to put the transmission and check if anything broke and make sure the linkage is OK.
Thank you very much for the suggestions.
Old Mar 12, 2012 | 07:12 PM
Finally got time to get back home. My pops said he was too busy to take 30mins out of his day to crack it open. Oh well. I took the transmission apart and found this:
I was wondering if it would be easier/cheaper to fix it or replace it. Found a SI Tranny fr $200
Old Mar 13, 2012 | 04:00 AM
crvtectim's Avatar
Default Re: Transmission Problems
If you trust the source and know the SI trans is good, get it!
Old Mar 13, 2012 | 07:24 AM
The transmission is from a transmission shop and they guarantee it for 30 days. I think I am going to go with the SI so I can feel like I'm going fast!
Old May 11, 2012 | 05:15 PM
Is it possible to put a 92-95 transmission gear set in a 88-91 case to utilize the cable instead of going hydro? Just trying to think outside the box.
96romaEK
Mar 11, 2010 06:01 AM
th3dynasty
Transmission & Drivetrain
Jul 20, 2009 05:30 PM
'95 BA8
Oct 11, 2007 01:47 PM
Melman872
Mar 17, 2006 09:47 AM
idreamsi
Feb 16, 2003 06:24 PM
