Wastegate placement concerns and advice needed
Old Jan 13, 2012 | 08:08 PM
roller3804's Avatar
Default Wastegate placement concerns and advice needed
I recently got this manifold for my turbo build. This was a good deal and I didn't want to pass it up.
The welds look decent. Some of them look autogeneous almost but its hard to say since its coated. I could always go back over them with some filler passes.
I am concerned about the wastegate placement being on runner #1. It is pretty close to the collector but from my understanding the wastegate runner needs to be fed from all four runners and at an angle in the direction of the exhaust flow.
What do you more experienced guys think?
If I do need to change it my plan is to cut the wastegate runner off and patch the hole and weld a new runner right in the center of the collector.
Any advice is appreciated.
Old Jan 13, 2012 | 09:09 PM
wittyworks's Avatar
Default Re: Wastegate placement concerns and advice needed
Hmm, construction looks pretty good, but I wouldn't ever place a wastegate there unless it was necessary for fitment reasons. It will probably work, but if you want to fix it wouldn't be a bad idea, except the patch would need to be smoothed on the inside ideally.
Old Jan 13, 2012 | 09:18 PM
SovXietday's Avatar
That is a fairly common wastegate placement for cast manifolds.
It works best with smaller hotsides that create a lot of backpressure. Essentially the exhaust gas gets backed up behind the turbine, and it is forced to leave through the low pressure area that is the wastegate off runner 1.
Usually, the larger in turbine you go the bigger problem you have with boost creep. I have also seen issues with guys who have larger displacement engines (2.0+) who have overboost issues because when the wastegate can't evacuate enough exhaust to slow the turbine down before it reaches the desired pressure. Instead, it goes 3-4psi over, and then drops as the RPMs go up and backpressure increases (allowing the wastegate to be more efficient).
My suggestion, if you don't have space constraints, sell it, and get something with a better wastegate placement.
Old Jan 14, 2012 | 03:39 AM
roller3804's Avatar
Well I def have space constraints because I am keeping ac..
I don't think it would be hard to move the wastegate placement..Do you disagree?
The turbo is an sc44 with .63 A/R..Only gonna boost 8psi for now.
Old Jan 14, 2012 | 05:05 PM
roller3804's Avatar
Anymore thoughts anyone??
Old Jan 23, 2012 | 07:23 PM
NA James's Avatar
Leave it there. Should have no problems with your setup
Old Jan 23, 2012 | 08:54 PM
roller3804's Avatar
Any particular reason or theory behind that?
Old Jan 23, 2012 | 10:38 PM
recliner15's Avatar
Why dont you see if it meets your requirements first.
Old Jan 23, 2012 | 10:52 PM
wantboost's Avatar
Who is Mr Robot?
my manifold is a damn clone of yours... literally except my wg is on the other side... but I have no idea who made it
Old Jan 23, 2012 | 11:12 PM
b00stME's Avatar
i use to have the same manifold on my old b18a setup. its an old school revhard kit
Old Jan 24, 2012 | 06:03 AM
roller3804's Avatar
Did you have any boost creep or overboost problems?
Old Jan 24, 2012 | 04:06 PM
b00stME's Avatar
I was using a t3/t4 turbo on 10psi. and didn't have any boost creep or boost spike problem.
Old Jan 24, 2012 | 07:28 PM
Hawkze_2.3's Avatar
Sounds like you shouldn't worry about it until much later in the build when you can see if it is actually affecting anything...
That or throw it out the window
roller3804
Jan 24, 2012 05:57 AM
speedy108
Apr 26, 2005 06:31 PM
abmerop18
Jan 27, 2005 08:05 AM
420aNT
Mar 5, 2003 04:44 AM
