code 11? p30 ecu (del sol b16a swap)
Old Jan 13, 2012 | 07:21 AM
pip9's Avatar
Icon2 code 11? p30 ecu (del sol b16a swap)
I just bought a 95 del sol and Im getting a cel code 11 I believe, one long flash followed by one short flash. I cant seem to find much info on it. All i found was that its a ecm code. Engine seems to run ok. Im not sure if vtec is kicking in and it feels like its misfiring in third gear and up.
Old Jan 13, 2012 | 07:55 AM
grumblemarc's Avatar
The Grumpiest
Default Re: code 11? p30 ecu (del sol b16a swap)
No 11 in this list.
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
38 Secondary vtec solenoid on JDM 3 stage D15B Vtec ECUs (P2J)
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
70 Automatic transmission problem
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
90 Evaporative Emission Control System Leak
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
Are you reading this off of Hondata by any chance?
https://honda-tech.com/forums/engine-management-tuning-124/cel-code-11-overheating-2569063/
Old Jan 13, 2012 | 10:00 AM
pip9's Avatar
As far as I know the car does not have hondata
this is the list I found:
Code 0 and 11 Electronic Control Module (ECM)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evaporative emission control system
Old Jan 13, 2012 | 01:03 PM
jbpnoman's Avatar
11 is usually used by tuning software to indicate something is wrong. Do you know if the ECU is chipped?
Old Jan 13, 2012 | 01:10 PM
Former User's Avatar
Is it codes 1 and 10? Post a video.
Old Jan 18, 2012 | 01:39 PM
pip9's Avatar
it turns out its code 10 and 1. I looked at the link in your sig ron and its 2.5 seconds delay between the flashes. Im getting three codes now. 10, 1, and 23. thanks.
Old Jan 18, 2012 | 04:38 PM
Now reset the ECU to see whether any of the codes repeat.
EMTIV09
Engine Management and Tuning
May 16, 2011 06:03 AM
93b20z
May 18, 2009 04:59 PM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
