Mini me swap 96 y8 head and IM on 2000 civic Air injection issue?
Old Jan 12, 2012 | 03:03 PM
jacekattack's Avatar
Default Mini me swap 96 y8 head and IM on 2000 civic Air injection issue?
I tried to research but couldn't find anything. I have a 2000 civic with a y7 and I want to do a mini me swap. I have a parts motor 96 y8 with ecu and everything but my problem is this .... 99-00 have air injection and 96-98 dont have air injection. Would this cause a idle problem? is there any bypass or trick ? or do I have to go out and buy a 99-00 IM?
Old Jan 12, 2012 | 05:12 PM
sde780's Avatar
Default Re: Mini me swap 96 y8 head and IM on 2000 civic Air injection issue?
What is air injection? IACV? Idle Air Control Valve, is this what you're talking about? I remember reading that the automatic and manual cars have different ones.
Old Jan 12, 2012 | 05:57 PM
motegicivic's Avatar
No the iacv, the 99-00 has a cold start valve I think it's iac the 96-98 y8's do not have it.
I can not remember if the y7 has the valve or not. I think if you go with a 96 IM you should be fine, or if it is 99 IM you plug the hole.
Old Jan 12, 2012 | 06:09 PM
HondaPartsHero's Avatar
Technical Hero
You'll be fine unless you lived in California and they'd look for it. If you have the whole Y8 engine you won't have to add the air injection.
Old Jan 12, 2012 | 06:40 PM
apexi_rsx's Avatar
you are going to need a obd2b-obd2a conversion harness when running a 96 ecu in a 00
Old Jan 12, 2012 | 06:47 PM
Wrona's Avatar
you will be fine as long as the head matches the intake manifold you are right the 99-00 Manifold has Cold Start valves or holes whatever you wan't to call it, but since you have a 96-98 head and intake manifold with a matching ECU you will be fine all you need though is a Obd2B to OBD2A conversion harness like mentioned above.
Old Jan 15, 2012 | 05:00 PM
Thx guys .... really appreciate the help
Old Jan 15, 2012 | 05:18 PM
Former User's Avatar
It's unique to 99-00 Y8 engines:
JDM-KIDD
Dec 1, 2010 12:42 PM
puthuff
15
Sep 15, 2010 12:07 PM
drewboy
Jan 5, 2005 03:20 PM
steve0unce
Nov 16, 2004 03:45 AM
Casey
10
Sep 4, 2004 10:42 AM
