stock b20vtec on 8psi tuned hp goals??
Old Jan 11, 2012 | 05:02 AM
mikeyjdm's Avatar
Default stock b20vtec on 8psi tuned hp goals??
Hey ht I got b20vtec that I'm currently boosting and i wanna wat kind of HP/power I'm gonna be making ,and I kno b20 have weak sleeves my setup consist of the following:
Stock 2000 b16 head
Stock b20b block
Eldebrock Victor x manifold
Skunk2 70mm tb
Rc 550cc
Ramhorn t3 manifold
Presicion 46mm wastegate
Garret 60-1
Tial 50mm bov
Big mishimoto intercooler
2.5 in intercooler piping
Type r oil pump and water pump
Blackworks breather box catch can
Gsr tranny non LSD
Getting tuned by xenocron on 8psi using hondata s300
What power will I be making with this setup
Old Jan 11, 2012 | 05:30 AM
ls_on_boost's Avatar
Default Re: stock b20vtec on 8psi tuned hp goals??
1001whp 2000tq lol u won't know till u put it on a dyno and start tunIng it no one can tell u they can tell u max power due to ur injectors being 550s
Old Jan 11, 2012 | 06:09 AM
mikeyjdm's Avatar
So do I need bigger injectors ? Wat size should I get 1000cc?
Old Jan 11, 2012 | 07:13 AM
Freshdot's Avatar
Get 880's and run 10psi, why sell yourself short? understood the b20 block is weak but most issues come out of poor tuning and xenocron is one of the best.
and don't look for HP or "goals" be focused on the gains.
Old Jan 11, 2012 | 07:52 AM
kyden's Avatar
i would worry about the rod bolts giving out well before the sleeves.
Old Jan 11, 2012 | 08:03 AM
mikeyjdm's Avatar
Thanks guys for the input I'm gonna be getting 1000cc injectors and arp rod bolts
Old Jan 11, 2012 | 12:06 PM
blackeg's Avatar
wat wat !
as previously stated, you need to get those arp replacement rod studs. to do that properly you need to check the big end of the connecting rod for ovaling after the stud install and if that turns out that its not true anymore then you will have to take the rods out and have them honed out.
if taking the block apart isnt in your near future then tell xenocron your setup and im confident he will pick the proper redline for your setup. as for power, 260-300hp is very probable depending on how much your b16 cams set you back.
Old Jan 11, 2012 | 04:37 PM
crvtectim's Avatar
Are you running ARP head studs also?
Old Jan 11, 2012 | 04:49 PM
jv88_dc2's Avatar
My setup
Refreshed B20z block
ACL bearings
Recondtioned stock rods w/ ARP rod bolts
Stock pistons
P72 GSR head
Stock manifold
Stock cams
Supertech valvetrain
Quick 4 turbo manifold
eBay 50trim
Precision 1,2000cc
Walbro 255 fuel pump
3inch downpipe(open cutout)
Tuned on Crome pro at 8psi(wastegate spring)
Makes 296whp 215trq with an AWESOME powerband, especially for daily driving
With that 60-1, you should see around 330, but with a higher RPM powerband
Godfrey34
Aug 13, 2017 04:46 PM
hondaEg_808
Apr 23, 2010 06:49 AM
2.0 and up
Apr 18, 2010 09:21 PM
chrisfromsrq
Mar 7, 2010 10:43 AM
19slocivic97
Apr 2, 2009 06:38 AM
