Bogging and idle problems after JDM B16A swap in ek sedan
Old Jan 9, 2012 | 04:47 PM
APZEE's Avatar
Default Bogging and idle problems after JDM B16A swap in ek sedan
I recently swapped a jdm b16a in my ek sedan and it has some problems. when i run the car and floor the pedal it gets stuck and boggs. don't know what the problem is. also when i start the car it idles from 2-2500 rpm and after it warms up a bit and restart the car it idles downs to 500-1000 rpm, but when i drive it after a while it goes down to like 100-300 rpm. besides that everything is good and runs great. I'm Running a stock P2T ecu. was wondering did i do something wrong with the swap? or is there a problem that needs to be solve. Help
Old Jan 9, 2012 | 04:49 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: JDM B16A swap in ek sedan problem
What trim was it EX, DX, LX? Any check engine lights?
Old Jan 9, 2012 | 09:21 PM
APZEE's Avatar
its a EX. yep check engine light is on, but due to the bottom o2 sensor
Old Jan 10, 2012 | 12:43 AM
LoLoCivic's Avatar
check if you swapped the idle air control valve plug and see if its mismatched
and see crank fluctuation sensor has been bypassed
Old Jan 10, 2012 | 01:28 AM
Technical Hero
Have you pulled the codes or are you just guessing that that is the only code?
Old Jan 10, 2012 | 08:15 PM
APZEE's Avatar
I had one of my shop buddy checked for me and he said i might need to run a jumper to a 0bd1 ecu, but not sure. I didn't see for myself,but my buddy said that its just the oxygen sensor when he did it.
Old Jan 11, 2012 | 08:38 AM
that_boy_sammy's Avatar
Get the code your self to make sure what the problem is . Your vehicle is in limp mode.
Old Jan 13, 2012 | 04:44 PM
APZEE's Avatar
just got the codes for my car.
p0113
p1106
p0122
Old Jan 13, 2012 | 04:49 PM
jbpnoman's Avatar
p0113 - Make sure your IAT is plugged in and is getting proper signal
p1106 - Check your MAP sensor
p0122 - Make sure your TPS is plugged in, and attach a voltmeter to it to make sure it's within spec. If not, there's a writeup on how to adjust it.
Old Jan 13, 2012 | 05:35 PM
Technical Hero
You could also have the TPS and MAP sensor plugged backwards. What are the colors you currently have connected to each sensor.
Old Jan 13, 2012 | 05:37 PM
Former User's Avatar
Default Re: Bogging and idle problems after JDM B16A swap in ek sedan
Reset the ECU to see whether all or some of those codes repeat after running the engine.
Old Jan 13, 2012 | 06:50 PM
APZEE's Avatar
ok. imma try all of that and see what happens. thanks for the help
Old Jan 13, 2012 | 06:58 PM
APZEE's Avatar
the wires i got connected to the tsp sensor colors are
yellow/red
green/white
red/green
are those the right one
Old Jan 13, 2012 | 07:04 PM
yellow/red
green/white
red/green
Those wires are for the MAP sensor.
Old Jan 13, 2012 | 07:08 PM
APZEE's Avatar
oo ic.. so that means i had it plugged wrong the whole time.......thanks a lot imma have to switch it. it was my first time doing a swap by myself.
Markb16a
11
Jan 22, 2013 09:19 AM
Ryanwill86
Nov 14, 2008 08:49 AM
lsvtecek18
Mar 5, 2005 09:27 PM
Downey
Feb 25, 2005 11:51 AM
tysir
Jul 18, 2001 07:15 AM
