GSR swap in 98 Civic
Old Jan 9, 2012 | 12:30 PM
fromthesun_93's Avatar
Default GSR swap in 98 Civic
Got a '93 del sol with a '95 gsr swap.
I want to swap the gsr into a '98 civic EX. Is this possible? If not what do i have to do? Will i have a problem with the harness of the car since the civic is a 98 (obd2) and the gsr is an obd1?
Old Jan 9, 2012 | 12:47 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: GSR swap in 98 Civic
The distributor, injectors and alternator won't plug in. You can use a distributor adapter, the ex injectors, and find a b series obd2 alternator. Also use the OBD1 ECU if you can.
Old Jan 10, 2012 | 06:34 AM
typerturbo29's Avatar
you would also need the 99-00 si rear bracket
Riptide101
Jul 17, 2017 09:35 AM
jrsh0526
Sep 11, 2012 12:17 PM
fromthesun_93
Honda Civic (2006 - 2015)
Jan 8, 2012 09:33 AM
thurmondauto
Aug 11, 2009 08:44 PM
moto1320
13
Mar 26, 2005 04:55 AM
